Latest: hulkbaja
Overall: 3594
Visitors: 110
Total: 110
07: Event Calendar
11: Event Calendar
18: Event Calendar
21: Event Calendar
44: Event Calendar
47: Event Calendar
48: Event Calendar
51: Event Calendar
60: Event Calendar
61: Pictures
81: Event Calendar
84: Pictures
85: Event Calendar
98: Event Calendar
104: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Back firing on deceleration
pschneider
pschneider
Post Post subject: Back firing on deceleration
Posted: Thu Sep 16, 2010 09:54 PM
Just put a new tri mil exhaust on my bug since my old exhaust was rusting off, and threw a pod filter on there and now I am getting back fires when I let off of the accelerator. I have read that it could be leaks in the exhaust but I am not sure. Any help would be appreciated.
kyle_pc_75
kyle_pc_75
Posted: Thu Sep 16, 2010 10:46 PM
Yep, most likely exhaust leaks. Check your bolts and gaskets for tightness. Flanges are sometimes not quite flush and may need double gaskets.
Kyle
Post Post subject: Re: Back firing on deceleration
Posted: Fri Sep 17, 2010 01:42 PM
Exhaust leak. The thin exhaust flanges are often slightly bent as delivered.
If you don't see carbon tracks have some one block the exhaust while it is running and you should be able to find it.
pschneider
pschneider
Posted: Fri Sep 17, 2010 02:38 PM
I think the leak is coming from where the exhaust meets the heater boxes. I know that the gaskets there were looking pretty rough but I didnt have a problem with my old exhaust. Ill see what I can do. Thanks guys.
Posted: Fri Sep 17, 2010 04:11 PM
New gaskets and a bit of muffler cement work great on heater box to header connections.
pschneider
pschneider
Posted: Fri Sep 17, 2010 05:45 PM
Does anyone know what the circular gasket between the exhaust and the heater box is called?
Posted: Sat Sep 18, 2010 04:25 AM
tail pipe installation kit 111 298 051 may have a letter at the end
No new posts VW Volkswagen & Baja Bug General Discussion will a superbeetle back seat fit into a 68 bug? 3 jasonrc2008 1962 will a superbeetle bac...
 Tue Aug 28, 2012 11:11 PM
No new posts VW Volkswagen & Baja Bug General Discussion HEY!!! We're Back :) 2 bajawarrior 2279 Re: HEY!!! We're Back ...
 Sun Jul 22, 2012 08:57 PM
Mykul View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Cobverting baja back to normal 3 mikeymike 2348 Cobverting baja back t...
 Mon Nov 21, 2011 11:39 PM
mikeymike View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Back 1 WaBaja 2309 Re: Back
 Fri May 06, 2011 02:58 AM
VIN70 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Baja bumpers front and back
utah stupid laws
3 bajaben1 5522 Baja bumpers front and...
 Thu Apr 21, 2011 04:00 AM
