Visitors: 73
Total: 73
12: Event Calendar
43: Home
44: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- long travel
long travel
thext94
thext94
Post Post subject: long travel
Posted: Tue Mar 09, 2010 06:45 AM
i want to get long travel a-arms for my bug but i dont want to buy a whole kit thing. i'm trying to find someone i could pay to make some. is there anything else i would need to do if i make it 3 or 4 inches wider? like new brake lines etc.
thanks, tyler
Posted: Wed Mar 10, 2010 06:10 PM
The shop you charge to build your front end will generally set up the brakes and steering etc. So yes, you will need steering and brake hose changes. Along with a lot of work for the a arms.
Baja_Blue
Baja_Blue
Posted: Sat Apr 17, 2010 09:22 PM
Here's a bolt on A-arm kit that comes with everything and gets you 6" wider and 12+ inches of travel
a-arm.com/
Matthew 5:14-16
Post Post subject: Re: long travel
Posted: Sat Apr 17, 2010 11:39 PM
a-arm.com/
I dunno- if I'm gonna cough up 3k for a-arms, I want quite a bit more than 12" of travel! I'm just sayin... Wink
Posted: Sun Apr 18, 2010 02:29 AM
But they are a arms. Very Happy I agree $3000 would buy Wood's 4" longer arms, combo spindles and coil overs.
Baja_Blue
Baja_Blue
Posted: Sun Apr 18, 2010 10:53 PM
or just custom build them... Wink
Matthew 5:14-16
jon6.0
jon6.0
Posted: Mon Apr 19, 2010 01:44 AM
Unless you are going to fab the a-arms yourself and figure out all the neccessary angles for a good handling car, then you are going to pay more than $3k for a shop to do it for you. You also don't want to use a shop that just does sand cars, because they typically don't have "correct" suspension geometry for a car actually used on the road and dirt. Sand is a different animal and more forgiving for crappy suspension design. My other question is have you ever riden in a car with an actual "good" 12 inches of travel? A lot of people will also say they have more than they do to sound impressive.
1967 Baja
2005 GTO
2009 Speed Triple
THORrider05
THORrider05
Posted: Mon Apr 19, 2010 03:35 AM
check out crumco motorsports, he's my neighbor 2 streets over.
thext94
thext94
Posted: Tue Apr 20, 2010 05:13 AM
that a-arm.com kit looks pretty rad. alot of cash to drop on the bug though. maybe just a wider beam for now to match width with the rear
Posted: Wed Apr 21, 2010 06:45 AM
He's just a few blocks over from me too. !!!!!!!
Posted: Wed Apr 21, 2010 01:18 PM
I have around 10" or more with the coil over and heavy duty trailing arms on my Baja. Works just fine. You can always spend more money but the way that the VW supension folds back is a great when goin forwared. reverse it's not so good, that is what A-Arms have over the VW trailing arms works the same forward or reveres. But I bet you spend more time in 1 of the 4 forward gears than you do in the 1 gear with the R...
thext94
thext94
Posted: Wed Apr 21, 2010 03:31 PM
where did you get your heavy duty trailing arms from?
Posted: Wed Apr 21, 2010 03:42 PM
Do not recall, but I'm sure you can get a set at chircos.
You will have to extend your front end to use them. So if your building a cage it would be a great idea to have them. if not then work with what you have. if you do not break it do not fix it Smile
Traling Arms 2 1/2 Longer, Coil Over Front , Set Of 4 [CPR405148] $259
Posted: Wed Apr 21, 2010 04:09 PM
Besides Chirco, Bugzilla makes them. I got mine from Woods Wheel Works. Fodrills makes them. In Ca. you have Tweeds Designs.
jon6.0
jon6.0
Posted: Wed Apr 21, 2010 04:30 PM
I've got the 4" longer Bugzyla chromoly ones. They are good pieces.
1967 Baja
2005 GTO
2009 Speed Triple
No new posts New Members Newbie from "florduh" here. Mid travel build. 9 shawn813 4704 Newbie from "florduh"...
 Thu Apr 18, 2013 11:13 PM
shawn813 View latest post
75 T_Town_Baja 99191 Re: Mid Travel Manx - ...
 Sat Dec 01, 2012 09:19 PM
jmert View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Wheel travel stock vs. 3x3 6 ghettodish 7189 Wheel travel stock vs....
 Tue Jan 31, 2012 02:57 AM
No new posts VW Volkswagen & Baja Bug General Discussion Well that didn't take long 7 DanMach 4817 Well that didn't take ...
 Thu Jan 20, 2011 10:58 PM
No new posts VW Volkswagen & Baja Bug General Discussion Hey Guys......long time just to busy
15 bajawarrior 8725 Re: Hey Guys......long...
 Fri Dec 10, 2010 03:22 AM
kellyj994 View latest post
