Latest: jor_dang420
Overall: 3597
Visitors: 116
Total: 116
19: Event Calendar
26: Pictures
27: Pictures
28: Garage
31: Pictures
32: Pictures
60: Event Calendar
66: Pictures
79: Pictures
98: My Account
113: Event Calendar
Baja Forums -:- AzBaja.com Members -:- New Members -:- Greeting from Camp Verde
The following users give thanks for this topic 51BUG50 - Sun Oct 16, 2016 06:00 AM
azranger
azranger
Post Post subject: Greeting from Camp Verde
Posted: Fri Sep 29, 2006 06:12 AM
I found this site by doing a google search for Volkswagen Baja. I live in Camp Verde at a school in Lake Montezuma. I have five kids and am building this project with my 10 year old son. It will be his run-around car when he get old enough to drive.
I just picked up this little guy. I called my wife and she said "just do whatever you want." When I came home and asked for the checkbook I found out that "just do whatever you want" does not mean the same thing to her as it does to me. I told her that I already commited to buying this buggy so she reluctantly let me.
I thought I had one bad mother buggy that with a little paint and rims/tires but after viewing pics and messages on this board I can see that I have gotten myself into something a whole lot deeper than what I imagined when I saw this in the weeds by the side of the road.
I only talked to the wife of the guy who owned this. I hope he was aware that she sold it. She said that it has a bus transaxle and I noticed that it had disk brakes on the front. The interior is great except for a lot of dog hair
I will probably be asking a lot of questions because I have no experience with mechanics.
Post Post subject: Re: Greeting from Camp Verde
Posted: Fri Sep 29, 2006 06:25 AM
Welcome!
thats a fine baja you have there!
if ya need it test drivien, let us know Very Happy
ask all you want.
tell the wife that she can play with the "stick" when the cars ready Razz Very Happy
azranger
azranger
Posted: Fri Sep 29, 2006 06:54 AM
I'm actually very fortunate. My wife might complain but she lets me get away with a lot of crap.
I need to start looking for these items. New window seals and basically whatever it takes the windows to roll up normally including the handles, exhaust, carb, rims/tires, guard for the front cage for the back and probably a bunch of other stuff. Do you recommend online or are there some good places to buy (preferalby north phoenix or above)?
Thanks.
Bahaw
Bahaw
Posted: Fri Sep 29, 2006 07:20 AM
azranger,
Welcome to AzBaja! You will be able to find good used parts here at the "I have something to sell!" thread. BugZila has parts for sale and so do I along with many others. We are also willing to help in any way we can. Advise? Questions? Just ask!
My son-in-law recently got me into vw bajas and now I have the "Bug" bug bad! I know about 327 Chevy's, the 389 Pontiac engine in the 1964 GTO, but vw air cooled engines are new to me and this site and these guys have helped me a lot with the questions and answers found here.
Good luck with your baja. My family and I may have to make a trip up to check out your bug project!
Jake
azranger
azranger
Posted: Fri Sep 29, 2006 08:32 AM
I'm excited to get started. Let me know when you're headed this way.
Posted: Fri Sep 29, 2006 03:49 PM
according to your 2 pics, the wheels look fine, maybe some new tires for it.
whats wrong with the :
exhaust?
carb?
are you askin about a skid pan for the front and rear?
you could put an aluminum plate in the front if you desire. there should be a steel or aluminum plate in the rear UNDER the trans and motor. got one???
either fab it or look here: www.chircoestore.com/c...571e4e2707
go through anr check the wheel bearings, repackem with the good grease (marine if your drive a lot in the rain or puddles). grease the whole front end, e brake cable (if it has a zurk). check the drive shaft boots (cv's) for leaks, cracks, tears.
change all of the fuel lines if its been sittin for a while (pull the fuel tank to get the rest of the lines - 4 bolts or so) and change the fuel filter.
will it start at all?
oh yea, get these books:
How To Keep Your Type 1 Alive, For The Complete Idiot
Baja bugs and buggies
those are a good start.
azranger
azranger
Posted: Fri Sep 29, 2006 09:24 PM
Bajafun - that is great info. I will do all of those things. I am going to get new tires. What to you suggest for an All Terrain.
It runs but cuts out big time in first gear when you take off.
The exhaust is all rusted and has been welded and rewelded a thousand times. Were going to tinker with the carb and see if we can get it going.
Thanks,
DP
Posted: Fri Sep 29, 2006 10:37 PM
run lt at's in the rear. 235's to 31" will work.
fronts anywhere from stock 156/15 to 215/ 15 or taller if ya have the room to steer and such.
sounds like an ignition/ timing problem if its cuttin out. start with the fuel sytem as suggested. change the plugs (bosch or what ever the high performance ones are from chirco). change the wires, points and condensor. you may want to just buy the petronix electronic ignition pack for it. is it a stock vacuum advance dist or is it a 009? (no vac advance).
have your buddy get his good timin light (digital). set it to 7.5* btdc.
btw...what kinda carb? (look on the left side - i do believe- on the throat and it should say somethin like 32pict3 or so.)
azranger
azranger
Posted: Sat Sep 30, 2006 04:55 AM
Mine is a 30 Pict3.
This little pipe that is right above the "k" on broke was broken on both sides. It allowed the carb to move back and forth. We welded both of them and it is running alot better. It has been welded many times before so I think I need to do something different.
I ordered some Cooper Discoverer tires
from a buddy of mine for the back today.
Posted: Sat Sep 30, 2006 05:48 AM
drop $150 and get yourself a tri mill quad header exhaust...either stinger or u bend.
azranger
azranger
Posted: Sat Sep 30, 2006 06:21 AM
Where do I get the exhaust?
Thanks.
Say10
Say10
Posted: Sat Sep 30, 2006 07:49 AM
$150? or you can go economy and drop $60 or $80 bucks on a raw one and paint it flat black BBQ paint or ACE sells there own brand of bbq paint that comes in a aluminum finish and is good to 1200 degrees. Just used both on mine and looks sweet.
Posted: Sat Sep 30, 2006 04:49 PM
they are $150 at BAP
Karls Kustom- raw steel (if they still caryy it) about $100
order from magazine
check www.chirco.com if ya dont want to leave camp verde Wink
Say10
Say10
Posted: Sat Sep 30, 2006 09:02 PM
I just bought a tri mill at Bap, raw and spent $80 after taxes and a couple of cans of paint at like $3 or $5 a piece. The chrome ones at Bap are $120 plus tax.
madman74
madman74
Posted: Sat Sep 30, 2006 11:21 PM
Yep I just went by bap they have raw pipes for $69 I didnt check on chrome.
azranger
azranger
Posted: Sun Oct 01, 2006 01:11 AM
where BAP?
Posted: Sun Oct 01, 2006 02:48 AM
azranger wrote:
where BAP?
closest to you: bapimportparts.com/locations.html
Say10
Say10
Posted: Sun Oct 01, 2006 10:29 PM
The nearest one to you is at Cactus and 28th drive, right off the 17.
No new posts Events and Get Togethers World Wide Annual 400 mile camp out may 21-22 2016. SAT-SUN
Overnight run
92 Azdrtdog 35721 Annual 400 mile camp o...
 Wed Apr 24, 2019 02:25 PM
No new posts Events and Get Togethers World Wide Camp out 1 Dalton 1614 Camp out
 Tue Nov 07, 2017 06:02 PM
No new posts Events and Get Togethers World Wide Report Verde River Hot Springs 5 azdesertrat87 4022 Report Verde River Hot...
 Fri Jul 17, 2015 02:27 PM
No new posts Events and Get Togethers World Wide Memorial Day camp out May 25-27th 1 Dalton 1618 Memorial Day camp out ...
 Wed May 22, 2013 02:16 PM
No new posts New Members I got the Fever. Verde Valley VW fever 4 SIPER 3023 I got the Fever. Verd...
 Thu Jan 03, 2013 07:42 PM
