Visitors: 85
Total: 85
23: Event Calendar
32: Home
35: Home
59: Event Calendar
62: Event Calendar
63: Event Calendar
64: Pictures
78: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Blind Chickens Lift spindles for ball joint?
BajaJoe
BajaJoe
Post Post subject: Blind Chickens Lift spindles for ball joint?
Posted: Wed Dec 05, 2007 05:46 AM
As any one else try running these? I want the lift with out going to crazy switching pan heads to go link. looking for opinions.
Post Post subject: Re: Blind Chickens Lift spindles for ball joint?
Posted: Wed Dec 05, 2007 04:47 PM
I havnt used them, but it looks like a quality spindle. I just installed some BCR 5x5 arms on a 5 unlimited car and they are good quality.
BajaJoe
BajaJoe
Posted: Thu Dec 06, 2007 04:21 PM
thanks also in order to match the height of the front, what size rear arms would give me 3 in lift in the rear. could i get it from 3x3s i didnt really want to go much bigger
Posted: Thu Dec 06, 2007 09:20 PM
You may get there by re-indexing the rear torsions. I would do that first and see how it looks. Otherwise the 3x3's will get you up depending on droop/lift settings.
Crash
Crash
Posted: Fri Dec 07, 2007 05:16 PM
The 2x3's would get you a pretty good match and save you some money on axles. You could do a lift on the stock rear suspension but unless you have pretty big tires you will probably be on the stops if you want it level.
-Mark
Mark Johnson
Blind Chicken Racing
www.blindchickenracing.com
24 Kreed 20778 3" Body Lift, Class 11...
 Mon Apr 18, 2016 04:44 PM
Front End question
12 ButchW 5881 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
24 vwboat 8807 Re: lifted spindles an...
 Fri Mar 22, 2013 08:58 PM
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 2709 Re: bj front disk brak...
 Thu Dec 13, 2012 02:03 PM
No new posts VW Volkswagen & Baja Bug General Discussion body lift 2 elryano 2040 Re: body lift
 Thu Apr 12, 2012 09:58 PM
elryano View latest post
