Latest: BlackIrish05009
Overall: 3574
Visitors: 127
Total: 127
15: Event Calendar
28: Event Calendar
40: Event Calendar
50: Event Calendar
53: Event Calendar
69: My Account
71: Event Calendar
74: Event Calendar
76: Event Calendar
95: Event Calendar
126: My Account
1 2 3 ... 71 72 73 ... 103 104 105
Posted: Sun Dec 04, 2011 08:47 AM
As for what did I do with mine today?
I took it to an offroad race in the Mojave Desert where my son's team took a 1st place in 5/1600 class winning the MORE championship for 2 years in a row. My Baja was running poorly on the way home though, so it will get a tuneup tomorrow.
Posted: Sun Dec 04, 2011 06:44 PM
A finger between Richard
What can one DO......
Posted: Mon Dec 05, 2011 03:44 AM
Scored a pair of studded rear drum with backing plates, brakes and even the bearing caps for $20 at the swap meet at GCC this morning. Good thing too I stripped the splines in the right side yesterday.
Posted: Fri Dec 09, 2011 08:20 AM
Hitting the metal recyclers tomorrow......more stock!!!!!
Posted: Fri Dec 09, 2011 06:24 PM
So what is the seat out of and where are you going with it
Posted: Fri Dec 09, 2011 09:42 PM
Toyota 4x4 truck narrowed 4 in.
I goin to the woods wit a gun mounted ta da back of it............
with my 6 year old is grabbing gears in the middle and my 9 year old is rolling down the passenger side window. lol
Posted: Sat Dec 10, 2011 06:40 PM
Look forward to the completed seat
Posted: Mon Dec 12, 2011 06:07 PM
Replaced the broken motor mounts with a solid mount, & replaced the other rear brake drum.
Posted: Mon Dec 19, 2011 03:23 AM
Getting prepped for time off
Christmas Metal
Posted: Mon Dec 19, 2011 05:04 PM
Sold it on Saturday.
Posted: Sat Dec 24, 2011 03:34 AM
MOCKED up the rear bar after mounting the BENCH
Posted: Sun Dec 25, 2011 03:43 AM
BOXED IT
MERRY CHRISTMAS>>>>AZ
Posted: Fri Dec 30, 2011 12:41 AM
I'm getting mine back from my buddy's shop!!!!! 5 weeks seems like an eternity when the weather is nice. The sunroof should be welded shut, the rear slotted to get rid of the Toe out issue and camber adjusters installed.
Posted: Fri Dec 30, 2011 04:07 AM
I just drove it home from my buddy's shop an hour ago. It had a bad toe out and camber issue. He worked on the spring plates and trailing arms because it wouldnt adjust enough. He builds million dollar trophy trucks at FST Motorsports, so this a a little job for him. The bug's toe and camber look great!
He also built brackets to support the sunroof instead of welding it shut. Works great! I will fiberglass the rest shut to seal it up. Once I coat the body again with bedliner, you won't be able to tell it was a leaky sunroof.
I think I'll insulate the roof from the inside and build a headliner and door panels soon as well. Feels great to have my bug back!
Posted: Fri Dec 30, 2011 08:33 AM
Decided id run a oil gallery class with my 90.5 / once over case with big valve heads for my kids. The more I TEACH....the more I LEARN!!!
4 Admin_AzBaja 5829 Baja Bugs on Wiki need...
285 MusicManiac 221687 Re: Baja sightings
0 Northmountainauto 463 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1897 Baja hiding in Chandle...
Off-road event
1 wideopenmotorsports 1051 Re: Baja run in March
 Mon Jan 08, 2018 06:09 PM
