Latest: rcwtony
Overall: 3607
Visitors: 102
Total: 102
16: Home
27: Event Calendar
Bill's Baja project
1 2 3 4 5 6 7 8 9
Posted: Mon Nov 12, 2012 06:16 PM
Congrats. It did turn out looking good. So how is it running?
allisontech
allisontech
Posted: Mon Nov 12, 2012 10:05 PM
Couldn't get the single 40 tuned before bug jam so I put the dual ICT's back on for now, cruised at 2300 RPM at 65 and oil temp never got over 180. Drives like a Cadillac, "without power steering and ac" LOL
Posted: Thu Nov 15, 2012 05:34 AM
Well Allison Tech...I havent been on in awhile....and DAMN yours came out pretty sweet aswell
What can one DO......
allisontech
allisontech
Posted: Thu Nov 15, 2012 11:09 PM
Thanks POCman we are real happy with the way everything came together. Going to change the rear shocks to Rancho's or something like them and add a turbo and I'm done!
allisontech
allisontech
Posted: Wed Dec 19, 2012 10:55 AM
A little update to the single 40 carb adventure, I had some extra time so I completely disassembled the new carb I couldn't get tuned properly, what I found was disturbing, there were metal chips and casting flash in every passage,jets and tube, "no wonder the car wouldn't run". I thought the carb was ready to bolt on when it came out of the box,it was wrapped in a plastic bag and still had the smell of fuel from being tested. "When people suggest taking apart your brand new carb and cleaning it, LISTEN to them". Anyway I tuned the single 40 with 65 idles,150 mains,160 airs and didn't modify the bypass jet for the accelerator pumps. Mixture screws are now only 1 1/2 turns out and the 1914 is running amazing! Blow through T25 turbo is next!
Posted: Thu Dec 20, 2012 04:55 PM
You just discovered why they say that. Smile I have had a couple that even when cleaned no fuel would flow through the idles.
allisontech
allisontech
Posted: Mon Jan 14, 2013 11:21 AM
Parts for the Turbo are starting to arrive,I will get some pic's soon. I'm going to try a document the swap to turbo with lot's of pic's and a video at the end.
Stay tuned!
allisontech
allisontech
Posted: Fri Jan 18, 2013 10:50 AM
Here are some pic's of the turbo kit I'm putting together
Going to start the conversion after this weekend
allisontech
allisontech
Posted: Tue Jan 22, 2013 10:54 AM
Mocked up the turbo to see what piping I'm going to need.
Yummi
Yummi
Posted: Tue Jan 22, 2013 12:50 PM
Pretty! Will be fun when it is done.
Posted: Tue Jan 22, 2013 04:33 PM
Looks like that should put more power to the ground. Keep us up to date.
DirkBiggler
DirkBiggler
Posted: Wed Jan 23, 2013 04:45 AM
Awesome!!!
I needs me some that... some day.
Did you TIG weld the flanges?
allisontech
allisontech
Posted: Wed Jan 23, 2013 11:28 AM
Flange is tig welded along with the bracing, "I wish I could TIG but I had a local shop do it for me"
allisontech
allisontech
Posted: Sun Jan 27, 2013 01:53 PM
Turbo is mounted,just waiting on the intake charge piping and hoses, oiling system seems to be working fine,dumped the 1/2" drain back into the oil fill tube and looks like it flows well with a .060 restriction. Car starts and runs with the turbo emulsion tubes and pressure hat in place. We are getting rid of the mechanical fuel pump and changing over to a 140 GPH electric with a 1:1 boost referenced regulator, I'm afraid the mechanical pumps 5 psi max may be a problem if the boost spikes to 6 psi or so. Working on the ignition advance until the other parts come in.
allisontech
allisontech
Posted: Tue Feb 19, 2013 02:45 AM
Pic's got all screwed up on photo bucket, "Sorry" Turbo is on and running really well, a little to well having trouble keeping the boost under 9 lbs, going to modify the waste gate more this weekend. The blow through carb is running a little fat down low but I expected that, advance is limited to 25 degree's. I only laid into the boost once in the top of second gear and at 9 psi this Baja pulled like a V8 car, really sets you back in the seat. I will get the pic's straightened out this week end. But here are a few
1 2 3 4 5 6 7 8 9
5 Admin_AzBaja 10431 Baja Bugs on Wiki need...
1569 mufasavnvmc 1145813 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
285 MusicManiac 276748 Re: Baja sightings
103 SuburbanLegend 159217 Carbon Footprint...aka...
 Tue Sep 03, 2019 03:15 AM
Mykul View latest post
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 2821 FREE VW BAJA'S
