Visitors: 354
Total: 354
48: Home
100: My Account
157: Baja Forums
163: Event Calendar
167: Pictures
178: Baja Forums
196: Baja Forums
197: AMAZON.com
198: AMAZON.com
200: Baja Forums
202: AMAZON.com
203: Pictures
204: AMAZON.com
205: AMAZON.com
206: Baja Forums
207: Baja Forums
208: AMAZON.com
209: AMAZON.com
210: AMAZON.com
211: Pictures
212: Baja Forums
213: Baja Forums
214: AMAZON.com
215: Baja Forums
216: Baja Forums
217: Baja Forums
218: Baja Forums
219: Baja Forums
220: Baja Forums
221: Baja Forums
222: My Account
223: Baja Forums
224: Baja Forums
225: Baja Forums
226: Baja Forums
227: Baja Forums
228: Baja Forums
229: AMAZON.com
230: Baja Forums
231: AMAZON.com
232: Baja Forums
233: Baja Forums
234: AMAZON.com
235: Baja Forums
236: AMAZON.com
237: Baja Forums
238: AMAZON.com
239: Baja Forums
240: AMAZON.com
241: AMAZON.com
242: My Account
243: AMAZON.com
244: AMAZON.com
245: AMAZON.com
246: AMAZON.com
247: AMAZON.com
248: Baja Forums
249: Baja Forums
250: Baja Forums
251: Baja Forums
252: Baja Forums
253: AMAZON.com
254: Baja Forums
255: Baja Forums
256: AMAZON.com
257: AMAZON.com
258: AMAZON.com
259: AMAZON.com
260: AMAZON.com
261: AMAZON.com
262: AMAZON.com
263: AMAZON.com
264: AMAZON.com
265: Baja Forums
266: Baja Forums
267: AMAZON.com
268: AMAZON.com
269: AMAZON.com
270: Baja Forums
271: AMAZON.com
272: Baja Forums
273: AMAZON.com
274: AMAZON.com
275: AMAZON.com
276: AMAZON.com
277: Baja Forums
278: Baja Forums
279: AMAZON.com
280: Baja Forums
281: Baja Forums
282: Baja Forums
283: Baja Forums
284: Baja Forums
285: Baja Forums
286: Baja Forums
287: AMAZON.com
288: AMAZON.com
289: Baja Forums
290: AMAZON.com
291: AMAZON.com
292: AMAZON.com
293: AMAZON.com
294: AMAZON.com
295: AMAZON.com
296: AMAZON.com
297: AMAZON.com
298: AMAZON.com
299: AMAZON.com
300: AMAZON.com
301: AMAZON.com
302: AMAZON.com
303: AMAZON.com
304: AMAZON.com
305: Baja Forums
306: Baja Forums
307: Baja Forums
308: Baja Forums
309: Baja Forums
310: Baja Forums
311: AMAZON.com
312: Baja Forums
313: Baja Forums
314: Home
315: AMAZON.com
316: Baja Forums
317: Baja Forums
318: Baja Forums
319: AMAZON.com
320: Baja Forums
321: Baja Forums
322: Baja Forums
323: Baja Forums
324: Baja Forums
325: Baja Forums
326: Baja Forums
327: Baja Forums
328: AMAZON.com
329: AMAZON.com
330: AMAZON.com
331: AMAZON.com
332: AMAZON.com
333: AMAZON.com
334: AMAZON.com
335: AMAZON.com
336: Baja Forums
337: AMAZON.com
338: Baja Forums
339: AMAZON.com
340: Baja Forums
341: Baja Forums
342: AMAZON.com
343: AMAZON.com
344: AMAZON.com
345: AMAZON.com
346: AMAZON.com
347: Baja Forums
348: AMAZON.com
349: AMAZON.com
350: AMAZON.com
351: AMAZON.com
352: AMAZON.com
353: AMAZON.com
354: AMAZON.com
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- "Project Basket Case" - 1967 VW build
ChinookFE
ChinookFE
Post Post subject: "Project Basket Case" - 1967 VW build
Posted: Thu Jun 28, 2012 10:02 PM
I decided to start a build thread for my project before I got to far into it. Since I'm completely new to these things, I figured this would give you guys a chance to spot any mistakes before I make them and help me out with anything that might be common knowledge to you guys that I may overlook.
So without further ado, I'll catch you guys up to where I am now.
The car is a 1967 VW Beetle, that we originally thought was a '62 until we rechecked the V.I.N. I bought the car off of a friend at work for $500 which was a good deal for both of us considering he got the car for free. I had been trying to get the car from him for a long time, even when we we still stationed in Texas because the body was already cut up for a Baja and I have always wanted to build a Baja. He finally realized that he was never going to restore it original and decided to sell it to me.
This was the car as it sat when I bought it, and where it is still sitting in his garage because I don't really have anywhere to keep it right now. You can see where the name "Basket Case" came from. Just about everything was stuffed inside the car.
I began tear down on the motor and hit a snag when it came to the flywheel gland nut. My roommate and I tried as hard as we could to break it lose with an impact gun while holding the flywheel in place with a screwdriver to no avail. I did some research and discovered that this little nut is torqued on at almost 300 ft/lbs and that there is a flywheel lock that bolts on to hold the flywheel in place. I ordered the lock and put it on yesterday and tried again with the impact to break it lose but no dice. The engine then got cargo strapped to the bed of my truck and we went at it with a 1/2" breaker bar and a 6' piece of pipe. This resulted in twisting the head right off the breaker bar.
We grabbed a second breaker bar and were finally able to get it off. In the picture you can see the nut and the two pieces of the breaker bar.
After that, the rest of the teardown was pretty straightforward.
Got all the internal out of the case.
I took the case to the solvent tank at the Auto Craft Center on post and tried to clean it up as best I could.
I decided that working on a tarp on the floor sucked, so I bought an engine stand.
I tore down the carb for a rebuild and realized that the pictures I took sucked, so I still need to work that out.
I sent the case and crank off to the machine shop to get cleaned up and checked out, as well as align bored.
Got the crank and case back from the machine shop. Apparently this thing was rebuilt once before, they put it on the line bore machine and it had already been done at .020 and didn't need it again. They did grind the crank down .030 though and all the connecting rods spec'd out good. The crank and case got a good dip in the hot tank and came out looking better than I though they would.
Unfortunately, I got a speeding ticket that I need to pay out of this check that is going to hurt the play money for a bit. Hopefully I can scrape together the cash for the bearing set so I can at least get the internals back in it.
That's as far as I've gotten so far. My goal for the project is to at least get the engine rebuilt and get the body work done and the car painted before I have to go to Korea for a year in Jan.
jone$yyy
jone$yyy
Posted: Thu Jun 28, 2012 11:59 PM
what branch are you in, and what base in korea i got to camp casey august 16 im in the army.
but great work making good progress
ChinookFE
ChinookFE
Post Post subject: Re: "Project Basket Case" - 1967 VW build
Posted: Fri Jun 29, 2012 12:04 AM
I'm Army. I'm heading to Camp Humphreys
spud
spud
Posted: Fri Jun 29, 2012 03:38 PM
Camp Humphreys is a great place to go. The barracks are new and modern eight story towers and the transportation around the post is excellent. They have decent buses that do counter rotating loops around the airfield. The only thing that sucked is that if you are in the hooker maint or flight companies you have a longer ride to work than the support guys at 602nd. Bikes are also a good way to get around but don't take your if you have to, there are abandoned bikes everywhere. When going to Seoul, get away from the heavily americanized area next to yongsan, learn the subway/train routes travel.
ChinookFE
ChinookFE
Posted: Fri Jun 29, 2012 04:18 PM
Thanks for the info. I'll be in the 47 flight company. I plan on getting out into the country as much as possible and away from the bases.
ChinookFE
ChinookFE
Posted: Sun Aug 05, 2012 03:09 AM
I've hardly touched the motor in a while. I've been waiting get all the bearings for the crank and cam from my local VW guy, but they haven't come in yet.
Anyway, today I managed to find a little time to mess with it a bit. I was able to get the new oil control valve and spring installed in the bottom of the case. I had to fashion a homemade lathe out of a cordless drill, a bolt, some epoxy and some sandpaper so that I could mill the valve down a hair to get it to fit right, but it's in there now. I wish I had gotten pics of how I got it done. It was Alabama ingenuity at it's finest.
My plans of getting the engine done before I go to Korea has probably been derailed. I just found out that I'm going to VA for a few months for school and I'll get back with just enough time to pack up and clear Ft. Rucker. Hopefully I can at least get it back to a short block before I have to leave though.
On a side note, does anyone know a source for the crush washer that goes under the plugs for the oil control and pressure relief valves? I'd hate to have to buy a whole extra gasket set to get one washer and I can't find it for sale by itself anywhere.
blubaron66
blubaron66
Posted: Sun Aug 05, 2012 04:47 AM
I would suggest going to your local vw mechanic and ask them. I have a few mechanics in my area and find its a lot more convenient and usually cheaper to buy from them.
1199 Dalton 338631 My 69 project
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 3362 Project Purple People ...
26 1963BAJA 7351 The Socal Honda Build
 Fri Jun 23, 2017 12:15 AM
1963BAJA View latest post
Cheapskate special
26 Azdrtdog 11415 New father/son budget ...
 Fri Jun 16, 2017 10:26 PM
88 Dirtjunkie 62605 Project II
