Visitors: 119
Total: 119
05: Event Calendar
20: My Account
21: Home
65: Event Calendar
76: Event Calendar
85: Event Calendar
86: My Account
88: Text Menu
103: Event Calendar
106: Event Calendar
111: Event Calendar
1 2 3 ... 80 81 82 ... 103 104 105
Posted: Mon May 14, 2012 06:19 PM
Changed a broken cooling fan and took it to the car wash to clean out all the garbage under the cooling tins and between the cylinders. Also finally replaced the leaking oil cooler I had bypassed.
azdesertrat87
azdesertrat87
Posted: Mon May 14, 2012 11:18 PM
Hey Perri Hope to see ya on the 400 Miler, 4 days left and I am as giddy as a school girl, been working on the rail for over 10 months, got a whole new intake with a 65mm throttle body haven't got the turbo back on yet after the 400, I'm going to camp up on Four Peaks on Friday night, so can have a leasury b-fast and still be ready, take care my friend and hope to see ya up there! really want to see some AzBajas also!
73square
73square
Posted: Fri May 18, 2012 02:43 AM
Replaced the missing carb bits and got it registered in AZ (YAY!!) traced down and fixed the mystery, intermitent stereo short, replaced the break master cylider, and adjusted the rear lift gate door and seals to finally stop most of the exhaust leak.
That's done - Next!
Posted: Fri May 18, 2012 05:19 AM
Started installing my boxed arms on the vert and also the kid worked on the 1 piece starting the filling & sanding.
BearpawAZ
BearpawAZ
Posted: Fri May 18, 2012 08:09 PM
New front Shocks, and tightened the bolts holding gas tank, thus fixing the elusive rattle... much more to come... rack, seats, are next on list
Posted: Sat May 19, 2012 05:54 AM
Got my boxed arms on the vert, now just need to cut the stock shock mounts off and fab the new ones off of the roll bar. This also frees up the stock arms for project II which we will be converting to IRS soon.
Posted: Sun May 20, 2012 02:08 AM
Finally hit the local Tractor Supply and bought/installed a rain cap for my Baja Stinger. Seems to work well.
Posted: Sun May 20, 2012 05:29 AM
Footrest and two new race trim seats installed today.
shok
shok
Posted: Sun May 20, 2012 07:13 PM
Fixed the leaky driver's side axle seal.........I Hope!
Posted: Mon May 21, 2012 05:37 AM
Finished all the brakelines..Shock spacers and tweaking my torsion for 16 gallons in the rear seat with twin shock....Damn..AXLES at 20* but she rides Beautiful and Is TIGHT.
What can one DO......
phrydup
phrydup
Posted: Tue May 22, 2012 05:47 AM
installed intercooler, 145 watt alternator, smaller turbo, and tuned the engine to the new parts.What a difference. Next redo front beam and add front disc's. It never ends!!!
1971 Baja Bug conv, 3x3, 2.3lt Ford turbo, 5 rib 002
thing
thing
Posted: Wed May 23, 2012 10:02 PM
Today I'm working on the dash panels, getting them ready for gauges and new switches. I'm at the filling existing holes stage.
Posted: Thu May 24, 2012 03:29 PM
picked up a GoPro today Smile
BearpawAZ
BearpawAZ
Posted: Thu May 24, 2012 04:15 PM
for your GoPro.....
daystarweb.com/product...uctID=1216
Posted: Sat May 26, 2012 02:55 AM
is it the HD GoPro?
5 Admin_AzBaja 7333 Baja Bugs on Wiki need...
285 MusicManiac 246254 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 458 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1621 Re: Had to go play in ...
0 Northmountainauto 1769 Shop Baja
