Latest: jor_dang420
Overall: 3597
Visitors: 63
Total: 63
03: Event Calendar
11: Event Calendar
16: My Account
19: Event Calendar
29: Home
41: Event Calendar
44: Event Calendar
52: My Account
55: Event Calendar
62: Garage
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Shock Hoops
Shock Hoops
Post Post subject: Re: Shock Hoops
Posted: Mon Jan 23, 2012 04:43 AM
Started notching parts
The cross bar above the torsion.
2x3x1/8 flat on the ends curved to the bend in the body.
Torsion tie on the outside of the heating duct.
Didnt go with the inside due to
Heating hose....brake line and........PIVOT Bolt.
So much cleaner on the outside and with outside support.
Ill run my inside support off the horn.
Shock support runners off the croos bar will eventually tie to a support to the END of the horn.
What can one DO......
allisontech
allisontech
Post Post subject: Shock Hoops
Posted: Mon Jan 23, 2012 12:10 PM
Sweet!!
Posted: Wed Jan 25, 2012 09:21 AM
Ive fallen back too some stock geometry as far with BOTH these build.
Upon wanting my shocks inboard closer to stock.....im goin with a half box or trailing skid on the bottom of the arm that with gussets and bosses should bring me back close to the old stock tabs.
Then i might just second guess the build on the japelino
Posted: Wed Jan 25, 2012 09:27 AM
Ohhhh
And droppin down off the top of the trailer saved me 4 in. in height or more on the inside of the car.
Making more room with shallower wells.
Posted: Tue Feb 07, 2012 09:00 AM
im building off a new direction on this.
Looked a couple other ways but it still comes back to the same points.....DAH
Maybe with some new pipe and a new die.....HMMM
CROSSROADS & thought.....but
Posted: Tue Feb 07, 2012 09:17 AM
GOTTA....
tweak these templates a touch to be able to slip the body off.
Posted: Thu Feb 16, 2012 08:37 AM
Move my starting point off the torsion and onto the horn.
Itll end back on the horn just forward of the CV.
Ebrake housing is my only problem but will reroute after i cut the hole for the 1 1/2" Tube.
Depth of the installation will stay shallow due to the other lines involved....FYI fuel on the left.
Other than that.
Hmmm............
3/4 DOM tomorrow.
and we'll she where she goes from there.
Posted: Mon Mar 05, 2012 03:14 PM
So the lift opened back up after my bother knock out 5 watercooled.
The Recluse
Posted: Wed Apr 04, 2012 07:43 PM
Hey POCman you got any updates on you progress?
Posted: Thu Apr 05, 2012 06:05 AM
Welded three through tube bosses per side on this particular arm. 90 degree at full bump with the dual set up split the middle leg with one more boss postition forward of those. Im ready for the lift to open back up to fully weld in the spider legs. But these damn watercools keep coming in with blown head gaskets and are slowing down this build. Finishing up the a small hole in the frame head,,bedlining the pan,, and beefing up some stock arms. So not to have to get back in this one. LOL
My tall travel will be running the same design but with a couple tall hoop running from the same locations and going to the top of the fenderwell.
Im working to get a dual shock setup with one outbound and back on the 3x3 and one inbound and possibly forward on the arm ..... if permitting due to me wanting to seal the wells back up.
Im guessing my tall travel build to start bending late may- early june.
Posted: Fri Jun 01, 2012 06:02 PM
Body Dropped on yeasterday.....and im really wanting to throw this one the road.
allisontech
allisontech
Posted: Fri Jun 01, 2012 10:29 PM
Looks sweet!! I'm not going to post any pics of my shock set up that's for sure!
Posted: Sat Jun 02, 2012 08:24 AM
Ahhh Allison,
You cant keep me hangin like that...picspicspics
So sorry im working on hoops instead of the southern cage.....but its kinda wet up here and i need a solid body.
Posted: Thu Nov 15, 2012 06:05 AM
Well its been awhile.....been out playing with my work and im really like this hoop design and it will be the basis for my next couple of builds. Going to swap out the dual gas for a dual air just to see if i can soften the ride just a touch. Just seems a touch too much with my LATEST RAGE 28mm torsion.
Posted: Thu Nov 15, 2012 08:50 AM
My whole rear clip on my Japelino will just SLIP in on the next build to up the cooling.....though im not quite happy with the 10* mount..... itll have to work for this build. It not that bad but just wanting to look farther into the geometery of the Bus Trans for not so steep of a angle due to OIL!!!
Maybe a 50/50 but need to check the shift shaft.
15 onthefarm 11453 Number on the shock to...
 Sat Jul 28, 2012 05:03 AM
No new posts VW Volkswagen & Baja Bug General Discussion shock setup 5 thext94 4787 Re: shock setup
 Wed Apr 14, 2010 02:16 PM
No new posts VW Volkswagen & Baja Bug General Discussion I need a rear shock 0 perrib 1554 I need a rear shock
 Sat Jul 18, 2009 05:44 AM
No new posts VW Volkswagen & Baja Bug General Discussion Shock Towers new picks!
30 DRUMMOND 38820 Re: Shock Towers new p...
 Tue Sep 23, 2008 11:05 AM
No new posts VW Volkswagen & Baja Bug General Discussion Wet Suit Shock Barriers 3 57baja 2859 Re: Wet Suit Shock Bar...
 Wed Jun 18, 2008 07:21 AM
WaBaja View latest post
