Visitors: 122
Total: 122
11: My Account
58: Event Calendar
59: Event Calendar
100: Event Calendar
106: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- reverse lights
reverse lights
72BajaBen
72BajaBen
Post Post subject: reverse lights
Posted: Thu Nov 16, 2006 05:22 AM
So does anybody know how to hook up reverse lights? That is the only thing that i have to do now to make my car completely street legal. =]
I know that there is a switch for it somewhere...but i dont know where. and how to hook it up.
thanks
Post Post subject: Re: reverse lights
Posted: Thu Nov 16, 2006 05:49 AM
it's on the trans axle, it a button type switch the screws in.
it has 2 spade conectors. on my baja (I rewired every thing, NOT STOCK)
Run 1 spade to ground the other spade to the ground side of a realy 35/40 amp BOSCH (Black Cube Realy)
Ground-----------Button Switch @ Transaxle--------Neg Relay coil(Relay) Pos Relay coil---------- hot 12v aka battery better to switch hot lead vs cconstant so if you leave your baja in REV back up light will not stay on.
Ground-------Flood Light--------Contact side A (Relay) Contact side B----12v pos Batery
Just start at one end and wire it like above, it's in order and will work just fine
As you can se I have both paths for each part of the relay. I hope this helps if not I can make up a picture or somthing like that for you.
72BajaBen
72BajaBen
Posted: Thu Nov 16, 2006 05:57 AM
man i pic would be awesome. do i have to use a relay. it is going to stock reverse lights. i was told that it wasnt necessary for stock lights. but if i was going ot use anything else that i should use a relay.
thanks man
Posted: Thu Nov 16, 2006 06:06 AM
I think it should be fine with stock lights. Is some one has a picture of a trans axle can you post it. my transaxle is under my car at this time.
wire for that would be ------ = wire Smile
ground------(switch)------(light)------keyed pos 12v
72BajaBen
72BajaBen
Posted: Thu Nov 16, 2006 08:33 AM
wouldnt it be:
ground------(light)------(switch)------keyed pos 12v
i really appreciate it
Posted: Thu Nov 16, 2006 12:03 PM
you could do it that way to but you would have to run 2 wires back from the switch.
If your ground it right to the body of the car at the switch it will be like running one wire and if you do have any problms the light will act as a load/fuse. So if you do get a short in the switch to ground your light will turn on, no big deal. This a a switched ground set up.
the way you have wil use more wire as you double back and if you do get a short in the wire before the light it will put the load on the switch and wires and melt every thing. So if you do it that way you need a fuse.
Switched positive/hot wire
Ground----(light)----(Switch)----(Fuse)----Keyed 12v pos
Switched ground
If the Switch fails (shorts to ground) you will melt every thing from there to your battery. So make sure you protect it if your running it as switched pos.
A light is a fuse in a way, if you over load your circuit it will burn out. just make sure you run good wire. I used 12 and 14 on my car most people use 16 or 18.
Posted: Thu Nov 16, 2006 04:01 PM
just get an after market set of "reverse" lights from pep boys, or where ever. they come with instructions and relays.
72BajaBen
72BajaBen
Posted: Thu Nov 16, 2006 07:20 PM
AzBaja i see what your saying. the lights wont turn on unless they are grounded. man that is a good idea.
i think that im going to work on this this weekend.
thanks
Posted: Thu Nov 16, 2006 07:26 PM
And the light turns on over your head Smile
72BajaBen
72BajaBen
Posted: Thu Nov 16, 2006 07:28 PM
yes it does...thanks for the info.
azhunter
azhunter
Posted: Fri Nov 17, 2006 03:28 AM
Heres a pic for your info and reference.............
hope this helps.
No new posts Events and Get Togethers World Wide led auto lights 4 Stella2015 2398 Re: led auto lights
 Wed Apr 08, 2015 03:03 PM
No new posts Events and Get Togethers World Wide This was a fun get together. Christmas Lights Tour
Not Baja's but a great idea for a Baja run
7 Yummi 4654 This was a fun get tog...
 Sat Dec 14, 2013 10:48 PM
Yummi View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Need Help....Dash lights go out when I switch to high beams 2 jemizasi 2089 Re: Need Help....Dash ...
 Thu Nov 10, 2011 07:55 PM
DeathBug View latest post
what are yall's set'ups
7 vindeta 12870 Re: lights?????? (hea...
 Tue Oct 11, 2011 05:32 AM
No new posts VW Volkswagen & Baja Bug General Discussion no brake lights 4 danjones333 1692 no brake lights
 Sat Jun 06, 2009 09:24 PM
danjones333 View latest post
