Latest: BlackIrish05009
Overall: 3574
Visitors: 131
Total: 131
58: My Account
67: Event Calendar
73: Pictures
78: Event Calendar
86: Event Calendar
98: My Account
116: Event Calendar
119: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Mid Travel Manx - long road ahead
1 2 3 4 5 6
The following users give thanks for this topic perrib - Tue Feb 28, 2012 06:32 PM
siacs
siacs
Post Post subject: Re: Mid Travel Manx - long road ahead
Posted: Mon Aug 15, 2011 10:50 AM
Looks like you have been busy. Looks great by the way
T_Town_Baja
T_Town_Baja
Posted: Fri Aug 19, 2011 06:48 AM
I was able to get some more work done tonight.
I completed the stub axle installation - using early rear brakes (not sure I like having to use the spacer - might look into later wide-5 or type2/thing setup)
Beam visualization
These are all mocked Measurements:
As it sits now, the rear track width, drum to drum with 3x3's and early wide 5 brakes, is sitting at 62" - I have not installed the axles and CV's, nor have I adjusted the toe on the arms. My 15x8 wheels will add 5.5" to each side (outside lip)
Front track width is sitting at 64", drum to drum with +6 custom beam and 2.5x1" arms. Front 15x6 wheels will add 4" to each side (outside lip).
Overall wheel base, if I push the beam 8" will be somewhere around 106" at ride height.
Im to the point now where I really need to start designing the chassis, but I dont think I can do too much without the body - I could possibly mockup the base of the cage/chassis and mock the beam hang, but thats pretty risky without a body for reference.
More to come...
Blaine
T_Town_Baja
T_Town_Baja
Posted: Mon Oct 24, 2011 04:57 AM
Man its been a while, but I am still working on this project. I have been doing a lot of horse trading, buying and selling parts and acquiring many parts off my list.
I picked up a lot of good parts at Bugtober fest, enough to complete my motor build (1st motor). I decided to go with a simple refresh for my first motor, 1641, new heads, single weber 40. This will be used for the car while I build a bigger motor (the second AS41 I have) - probably just stick to a simple 1915 with dual webers.
I scored a killer deal on wheels and tires today. Got a brand new set of white, wide 5 spoked wheels. 15x8 rear and 15x7 fronts. They have brand new tires, 31x10.5x15's rear and some 235/70/15's up front. Picked these up for $180 for the set.
These should provide a great base to the car - not the exact tire combo I wanted but just couldnt pass up the deal. Now I can sell off my current set of Wide-5 wheels to someone who needs em.
Blaine
Posted: Mon Oct 24, 2011 04:24 PM
If you use CB unitech rods or Scats version the difference between a 69x94 (1915) and a 78.4x94 (2165) is the difference in crank prices. $289 vs $185. The larger engine works a lot less to get the vehicle moving. If your not using ported heads stick with the 1915.
I ran a 1835 with a Weber cam version of the VZ 15 with a single Dellorto and a 3 rib transaxle in my non caged Baja and it worked fine turning 31 10.50 tires.
T_Town_Baja
T_Town_Baja
Posted: Mon Oct 24, 2011 09:11 PM
What level of case clearance is needed to run a 78.4 crank though? I have always wanted to build a stroker, but having to clearance the case is what scares me off. I like doing everything myself if I can and have usually just paid the local shop to open the case (they dont clearance cases though).
Thanks
05grizzly
05grizzly
Post Post subject: Mid Travel Manx - long road ahead
Posted: Tue Oct 25, 2011 01:56 AM
just started my build going to be similar to your cept going coilovers in the rear. will start posting pics soon may need to pick your brain a bit never done a manx allways chevy 4x4s
T_Town_Baja
T_Town_Baja
Posted: Tue Oct 25, 2011 03:07 AM
For sure, hit me up anytime. This is my first Manx build, but I have built a few Baja's prior to this Smile
BTW, I intend to go full coil-overs in the future, I am building the car for coils, but running torsions and decent shocks for now. As with any project, it starts out pie in the sky, but ends up never getting their, this way I figure I can build a solid foundation have it drivable and usable, then continue to upgrade it over time - but still be able to use it.
siacs
siacs
Posted: Tue Oct 25, 2011 01:48 PM
Thanks
I think we can clearance the case ourselves. I plan on doing the same 78mm.
The 78 is doable. 82 needs much more clearance not sure I would try that one at least @ home with out a mill to make it nice. Others please chime in
05grizzly
05grizzly
Posted: Tue Oct 25, 2011 02:48 PM
not sure if your still interested in a body but scott over at mgf in san marcos has a yamaha blue body hell let go for 1500 i cant pony up that for a couple weeks.
T_Town_Baja
T_Town_Baja
Posted: Tue Oct 25, 2011 08:00 PM
I am definitely interested. I havent heard of MGF, but do you have a contact number? Do you know if its the widebody/raised body?
I will snag that now if its available.
Thanks
Blaine
05grizzly
05grizzly
Posted: Tue Oct 25, 2011 08:53 PM
7607448909 just so you know your taking my deal its the long body with built in lift updated dash you owe me. Let scott know toby gave you the info on it.
T_Town_Baja
T_Town_Baja
Posted: Tue Oct 25, 2011 11:13 PM
Thanks Toby, but I already talked to Scott (thanks Scott Smile ) Unfortunately it's not a mid-travel body, which I suspected with that price. The mid travel body is wider, taller and a one-piece unit - it retails for $2400. The one he has sitting there is a long-body, but not mid-travel - it wont work for me Sad
Thanks for the heads up though, I was super excited to jump on it!
Blaine
T_Town_Baja
T_Town_Baja
Posted: Wed Oct 26, 2011 10:20 PM
So I talked with Scott at FRPManx (MGM Plastics) about color selection. I want to run a bright color, but the green/orange/yellow I see everywhere and I want to be different. Thus, PINK!
I tossed the idea to the wifey and she loved it. After talking to Scott, he mentioned that he has only build 1 pink one (Pepto Bismol) and I found a picture of it:
I like it! We are definitely going to go pink with silver cage, black chassis. The only decision left is whether we want to go a little brighter pink, e.g. Hot Pink or just go with the Pepto Pink.
As it looks now, I will be ordering the body late December with the hopes of picking it up early January!
Blaine
05grizzly
05grizzly
Posted: Thu Oct 27, 2011 03:38 AM
maybe we can work him for a twofer deal ill be ready by them to purchase mine as well
T_Town_Baja
T_Town_Baja
Posted: Thu Oct 27, 2011 04:07 AM
Heck ya, I would be down for that. As December approaches, we will have to touch base on that.
On a side note, if anyone is looking for a manx project, here is a killer deal, just add motor and go!
http://phoenix.craigslist.org/evl/cto/2670164031.html
6 AZOffroadSwapmeet 2731 AZ Off-Road Swap Meet
 Fri Dec 09, 2016 03:37 PM
No new posts Events and Get Togethers World Wide Annual 400 Miler Off Road Run/Campout May 16-17th 6 azdesertrat87 5207 Annual 400 Miler Off R...
 Tue Feb 09, 2016 04:23 AM
No new posts Projects and Builds When Off Road Racing Was... 4 wideopenmotorsports 4780 Re: When Off Road Raci...
 Sun May 10, 2015 12:35 PM
46 1engineer 31262 The Phoenix Manx
 Tue May 27, 2014 10:31 AM
No new posts Events and Get Togethers World Wide Mojave Road 2013 - May 24-26th 4 Leatherneck 3531 Re: Mojave Road 2013 -...
 Sat Jun 29, 2013 10:48 PM
Leatherneck View latest post
