AzBaja Site info
GPS
Psuedo Class 11
Users browsing this topic:
None
Author |
Message |
+5
Post subject: Psuedo Class 11
Posted: Mon Oct 03, 2011 12:12 AM
I pulled the tank today. It will go to Hal's Radiator shop tomorrow.
_________________ If you blame others when you fail, give them credit when you succeed!
+5
Posted: Thu Oct 06, 2011 08:45 PM
I got the tank back and I painted the outside. I installed it and a new fuel filter. Took the car for a drive and the distributor was screaming at me at mid-range RPM and above. The bug also didn't have much power when it started screaming. Looks like I need a new distributor. I may spring and get a rebuilt 010 or 019, which ever is the right one for my engine. Or, a vacuum advanced.
+9
Post subject: Re: Psuedo Class 11
Posted: Fri Oct 07, 2011 12:35 AM
biblethumpncop wrote: |
I got the tank back and I painted the outside. I installed it and a new fuel filter. Took the car for a drive and the distributor was screaming at me at mid-range RPM and above. The bug also didn't have much power when it started screaming. Looks like I need a new distributor. I may spring and get a rebuilt 010 or 019, which ever is the right one for my engine. Or, a vacuum advanced. |
Distributor screaming suggest a lack of oil to the bushings. A shot of WD40 or ??? may cure your problem. they're supposed to get a drop of oil in the wick under the rotor at each tune-up Does yours have points still? Which carb do you have? that could affect your choice of distributor.
If you need to replace the distributor, keep in mind that Solex carbs later than 67 year model 30 PICT-1 don't like non vacuum advance distributors. I hear a lot of grief thrown at 009 distributors on the various forums these days, mostly because people try to use them with 34-PICT-3 carbs. If you have a single Solex carb with a large brass screw on the left side of the body, it won't like a 009, 010, 031, or 050 distributor.
Offroad racers are required to use Solex 30PICT-1 carbs on 1600 class races such as Challenger/9, 11, 5/1600 and 1600 Limited Buggy. Some are claiming 90hp these days with it. Available brand new with electric choke from EMPI dealers as 98-1288-B. 2011 EMPI catalog page 98.
There's also a lot of fuss about "Chinese made" 009 distributors and poor quality. Those who fuss try to lead readers to SVDA (single vacuum) or later DVDA (dual vacuum) distributors. So you either are buying a 40+ year old distributor, or a new one made on the same assembly line as the 009s they bag on.
_________________ Richard
+5
Posted: Fri Oct 07, 2011 06:12 AM
I purchased a 019 from Glenn on the Samba earlier today. I read good things about the rebuilt dizzy he has. He recommended the 019, so I hope I get the right one. I bought and paid for it before I read your post. I sure hope it works out for my '63 1385 with 1600 cam, stock exhaust and 30pict1 Solex carb. (Yes, I run points.)
+9
thing
+1
Posted: Fri Oct 07, 2011 08:23 PM
Reading about your 1385's really brought back a lot of memories. I've logged many off-road miles with 1385's, they are great little motors. Long live the 40 horse!
+5
Posted: Mon Oct 10, 2011 05:25 PM
Looks like the distributor should arrive today- problem is I am on vacation! I am glad to finally put a quality distributor. I hope that was the reason for the noise and performance issue. There is a chance my bearings on my generator are going though. I might have to pull it as well. I don't know if I should upgrade to an alternator or just replace it with another generator. I don't run a stereo yet or several sets of lights. I read about many alternator kits being junk from China. Any experience????
TINMAN
+6
Posted: Mon Oct 10, 2011 08:34 PM
I have chinese alternators on both my 66 street car and my buggy and I've had no problems but they are not driven on a daily basis,however the chinese starter that was on my buggy was a smoldering piece of trash in less than a year.
_________________ TRUMP 2020
+5
Posted: Thu Oct 13, 2011 06:51 PM
I installed the distributor and set the timing to 30* at full advance. I replaced a leaky gasket for the main jet bolt on the carb and tightened the fan belt. The noise turns out to be from the fan belt/generator but is now quiet since I tightened it up. I will drive it today and to the west side meeting tomorrow. So far, it is running great!
+5
Posted: Fri Oct 14, 2011 12:38 PM
The generator or voltage regulator went out last night. I was smelling something that was an electrical smell for several miles. I pulled over but couldn't see anything smoking. A few miles later, my generator light (red light) came on and the electrical smell went away. Since this happened shortly after I tightened up the fan belt because it was loose and making noise, I anticipate the generator went out. I hope to get it fixed before tonight's west side meeting.
+5
Posted: Sun Oct 16, 2011 06:23 AM
I picked up a generator and voltage regulator from Autozone, but was disheartened to find it was made in China. I pulled the old, Bosch generator out, after getting some advice from Wideopenmotorsports, Dirtjunkie and 64baja. I sent the Chinese parts back to the store, and will take the Bosch to Gen-Star to get rebuilt. I couldnt get the fan off, so hopefully they'll take it without an issue. Just an update. I hope to get it running again this week so I can take advantage of this weather, and start driving it!
+5
Posted: Mon Oct 17, 2011 06:18 AM
Change 72.... I picked up an alternator and stand from BAP. I was able to get the fan nut off with an impact wrench. I put the alt on and found that I now need a spacer under my carb because it contacts the alt. I think I got the wiring figured out. One heavy wire (8ga??) from the starter will go to the B+ post and the thin wire (idiot light???) will go to the D+.
I will need to buy longer 8ga wire to run from the starter since the old wire only went to the regulator. In the meantime, I will take the two 10ga red wires that use to run from the generator to the regulator (regulator mounted on doghouse) and connect them to the 8ga wire that is from the starter. Then run both 10ga to the single post (B+) on the alt. That sound right? Also, will. need 8 ga wire to run from the starter to B+ on the alt, or will 10ga work?
Last edited by biblethumpncop on Mon Oct 17, 2011 06:53 AM; edited 1 times in total
+9
+9
+5
Topics |
Replies |
Author |
Views |
Last Post |
Projects and Builds
3" Body Lift, Class 11 cage, Warrior Beam w/ 10" towers, 3x3
Go to page:
1, 2 ]
25 |
Kreed |
21699 |
3" Body Lift, Class 11... Tue Apr 10, 2018 02:26 PM Kreed  |
Projects and Builds
New Class 11 Build - PepeBlanco
4 |
pepeazul |
4069 |
New Class 11 Build - P... Tue Mar 22, 2016 01:19 AM MojaveRacer208  |
Projects and Builds
CLASS 5 Resurrection!
Go to page:
1 ... 3, 4, 5 ]
60 |
wideopenmotorsports |
40883 |
CLASS 5 Resurrection! Mon Feb 22, 2016 06:23 PM wideopenmotorsports  |
VW Volkswagen & Baja Bug General Discussion
5-1600 vs Class 11 Version 3
2 |
2738 |
5-1600 vs Class 11 Ver... Thu Oct 08, 2015 08:12 PM AzBaja  |
Projects and Builds
Class 11 PepeAzul
3 |
pepeazul |
4832 |
Class 11 PepeAzul Fri Jul 17, 2015 02:29 PM AzBaja  |
Picture Box
Great things to Buy
Other Sites
Parts - For your Car
