Visitors: 105
Total: 105
21: Home
37: Home
53: Event Calendar
84: Event Calendar
89: Event Calendar
Baja Forums -:- AzBaja.com Members -:- New Members -:- NEWBIE from PHILIPPINES
otomandaxis
otomandaxis
Post Post subject: NEWBIE from PHILIPPINES
Posted: Sat May 21, 2011 02:19 PM
Hello everyone..
I'm a newbie in this forum, i found this site because of my interest in buggy, I bought a junk VW and I want to make this a buggy type and ride it on the street...
My problem is where do I begin...
I find difficult to buy the frame plan because of my location, Can someone help me what is the easiest way to have in hand that buggy frame plans...
Thanks.. Some pictures of the VW i bought 5 months ago...
Thanks and I hope I am welcome in this community..
Best regards:
otomandaxis
Posted: Sat May 21, 2011 02:38 PM
Welcome and hope the best on your project
Post Post subject: Re: NEWBIE from PHILIPPINES
Posted: Sat May 21, 2011 05:22 PM
Welcome. You have a couple of options you can add a tube frame to what you have. The other is to make a completely new frame. Any muffler shop with a mandrell tube bender can bend pipes. The nice part about the first way,called a pan buggy is you will still have a four seat and already have the pedals and e brake set up.
crestfallen
crestfallen
Posted: Sat May 21, 2011 07:02 PM
Welcome! Nice project!
otomandaxis
otomandaxis
Posted: Sun May 22, 2011 04:44 AM
I want to make a new tube frame like on the samba.com, i have a hydraulic bender and I think I can do the bending jobs also with the welding, I have that TIG and MIG machine, my only problem is the frame plan so that I can start to work on it... how to have in hand that frame plan on amazon.com
I want this buggy as a model, really awesome...
Thanks,
BR..
Posted: Sun May 22, 2011 04:41 PM
The building Baja and Buggies book has a very good picture of a well tringulated race frame you can adapt to the size your looking for. Since you have the pan, beam and torsion measurement all you need is a good picture and you can figure out most of the measurement. Move the bottom of the beam forward for better handling. Keep in mind most old style rails are cramped. If you can find another rear torsion you can cut weld the two together to make it wider. Make sure you have six inches between your head and the top of the frame.
Posted: Wed May 25, 2011 06:42 AM
To build your own frame like the one in the picture, make the main tubes using 1-1/2" (3.8cm) outside diameter tubing, with .095" (2.4mm) wall thickness. For the smaller tubes in the sides, use 1" (25.4mm) with .065" (1.5mm) wall. MIG is the easiest and most effective welding method. TIG will work too and may look nicer, but is overkill. Tack weld everything and mock up the entire car with all parts bolted on before you fully weld the joints.
As Perrib said, make sure you have plenty of headroom when sitting in the seats. To make sure of this, select your seats before you built the top of the roll cage.
No new posts New Members The new newbie 3 carpermike20 2278 The new newbie
 Thu Oct 08, 2015 08:23 PM
No new posts VW Volkswagen & Baja Bug General Discussion newbie needs help! 2 iwannabajabug 2101 Re: newbie needs help!
 Thu Jul 24, 2014 12:36 AM
iwannabajabug View latest post
No new posts New Members Newbie from Washington State
1972 VW Baja
18 ButchW 9407 Newbie from Washington...
 Sun Jan 19, 2014 03:50 PM
ButchW View latest post
No new posts New Members Newbie from "florduh" here. Mid travel build. 9 shawn813 4695 Newbie from "florduh"...
 Thu Apr 18, 2013 11:13 PM
shawn813 View latest post
No new posts New Members Newbie 5 73square 4072 Newbie
 Fri Feb 03, 2012 03:46 PM
biblethumpncop View latest post
