Visitors: 90
Total: 90
58: My Account
89: Event Calendar
1 2 3 ... 56 57 58 ... 103 104 105
igivup30
igivup30
Posted: Fri Mar 11, 2011 05:35 AM
I put new tires on Bartholomew.
Posted: Fri Mar 11, 2011 07:08 AM
I DROVE mine for the first time in like two months! Runs like crap, but I still kinda like it.
AZ_Born_n_Raised
AZ_Born_n_Raised
Posted: Fri Mar 11, 2011 07:13 AM
Why's it running like crap az300x?
Ken48442
Ken48442
Posted: Fri Mar 11, 2011 03:03 PM
Nice tires igivup30. Looks good. What kind and size are they?
igivup30
igivup30
Posted: Fri Mar 11, 2011 06:02 PM
They are BFG 30 x 9.50 15, my buddy Mike at Tire Pros got them for me.
dansbaja
dansbaja
Posted: Sun Mar 13, 2011 05:34 AM
rebuilt my carb yesterday.
Posted: Tue Mar 15, 2011 04:45 PM
Went to check out an odd oil leak in my 1776 yesterday. Leak seemed to be up under the fan shroud. Oil was coming out at every bolt and hole in the shroud. Thought maybe the doghouse oil cooler was leaking. Although if it were, I would expect the oil to be blown out the air outlet. After pulling the shroud, there was oil all over, but no definable source. So I covered the Kadrons and sprayed it with degreaser. Still can't find it. So I took the coil off the shroud and bungeed it to the bumper cage and ran a temp wire from the terminal strip on the firewall. Hooked the fuel lines back up. Then started it up. The source of leakage was immediately visible. It's a crack in the top of the case from the upper forward cylinder stud at cylinder #1. It runs upward at a 45 to just to the rear of the large case stud to the top corner of the case, then it angles back at a 45 about 2-1/2" toward the case seam. It's actually outside the fan shroud, but apparently when the engine is warmed up and I'm cruising at speed, oil gets sprayed into the fan intake and then all over. So now I need another case...and of course I'm broke. I have to fix SOMETHING! The Baja is my daily driver.
TrailRail2110
TrailRail2110
Posted: Tue Mar 15, 2011 07:21 PM
Aren't cases for the most part a 100 bucks...but all other other work will be a pain. i wish you luck, my engine is also torn down and i get a list today of whats bad and whats not...
Rybob
Rybob
Posted: Tue Mar 15, 2011 08:32 PM
He decided he needed to have the Pertronix/MSD setup that came on my 1776 (hes my dad and he said it was his labor fee), and now that its installed, it runs like crap. We think its a defective box.
(o\|/o)
Rybob
Rybob
Posted: Tue Mar 15, 2011 08:38 PM
Cleaned grease off of trailing arms i am going to use on a LP setup. Great fun, but necessary in order to powdercoat them soon.
(o\|/o)
Posted: Wed Mar 16, 2011 03:29 AM
Cleaned and repacked all cv joints. Installed new boots. Cleaned and installed new spring plate bushing both inner and outer and reindect torsions.
Painted complete rear suspension after cleaning of the 40 year old grease.
The cv's are really a grease grimy mess. Glad that part of the rebuild is done.
AZ_Born_n_Raised
AZ_Born_n_Raised
Posted: Thu Mar 17, 2011 02:05 AM
Pulled the engine off so that it'd be easier to work on, got some self tapping 240mm head studs coming in the mail, hopefully that fixes the oil leak on the left head.
Hyperwrx
Hyperwrx
Posted: Thu Mar 17, 2011 04:47 AM
Race Trim seats and mounting brackets came in. Encountered a problem. With my 2" body lift the seats are too low. Built small risers to sit the seat on. Now the problem is the shifter is too low. I can't win. Haha.
Also bought 2 new rear tires. Goodyear Wranglers 31x10.5x15. Has some trouble with those as well as the rims I have are 2 piece and the center seam was leaking air so I had to clean up the joint and reseal the rim.
Having a tough time finding an aggressive looking tire in 235x75x15. Any suggestions?
Carpet kit, insulation, new master cylinder, cutting brake, new chrome engine tin, electric fuel pump, fuel regulator, Jaycee fuel pump block off plate, breather box kit, new crank pulley, DZUS fasteners for 1 piece hood all came in today. Gonna be a busy week.
bajaben1
bajaben1
Posted: Thu Mar 24, 2011 11:44 PM
Picked up my first of 2 baja's, this one, 65 with new rebuilt motor, (never started) roll cage( not installed) side brush bars (new uninstalled) baja kit installed front and rear cages, 2 poly racing seats without covers and 1 full pass. side floor (new uninstalled), it has been sitting in a storage shed for 2 or 3 years. I know it didn't happen if there aren't pics, i'll get them up tomorrow, by that time i'll hopefully have the second one 1969 without motor
TrailRail2110
TrailRail2110
Posted: Thu Mar 24, 2011 11:49 PM
I bought two lightly used high back poly jaz seats and covers for the buggy for less whip lash effect, i felt they were a good deal at $60 for the pair.
Now how do i mount them so i dont hit my head on the roll bar because they sit up a bit higher...?
5 Admin_AzBaja 7373 Baja Bugs on Wiki need...
285 MusicManiac 246572 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 491 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1635 Re: Had to go play in ...
0 Northmountainauto 1788 Shop Baja
