Visitors: 121
Total: 121
76: Event Calendar
87: Event Calendar
90: Event Calendar
117: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Roof Scoop?
Roof Scoop?
mikehtiger
mikehtiger
Post Post subject: Roof Scoop?
Posted: Sat Jan 29, 2011 07:29 AM
Hey guys!
I have acquired a free roof scoop for my '68 bug, and I'm trying to decide whether I should put it on or not. The inlet and the outlet for the oil cooler which is installed in the roof scoop go down (into the roof) and it seems like it would be tough to install it without creating a leak in the roof... I figured the rest of the scoop I could bolt/rivet in and then bondo over the lip to make it look smooth.. Any experience or suggestions about the roof scoops?
Thanks!
Post Post subject: Re: Roof Scoop?
Posted: Sun Jan 30, 2011 04:03 AM
If you keep your oil lines outside the car your only chances for leaks are where the hoses attach to the cooler (oil leak) and water leaking in where you attached it to the car.
Additionally, make sure you have some sort of fan for slow traffic driving. Scoop works great when moving, not so much when stuck in traffic.
mikehtiger
mikehtiger
Posted: Sun Jan 30, 2011 05:05 AM
Thanks Wideopen!
I just realized that I can probably drill a few holes in the roof scoop and flip the oil cooler around so the lines would run outside the car. I was planning on using gasket sealer on the bottom of the roof scoop where it touches roof also so hopefully that will stop any leaks.
Does anyone know if it would be a good Idea to hook up the new oil cooler in line with the old oil cooler (2 coolers) or if that's a bad Idea?
If I should only use the roof scoop oil cooler, I was thinking about mounting two fans on the outside of the scoop on the back to help move air when it is stopping... Maybe I could tie them into the brake switch?!
Very Happy
Posted: Sun Jan 30, 2011 05:56 AM
Most people run the Oil lies out the side of the cooler and down one of the "C" pilers in the back.
Most or the ones that look the best use the braided line with the Red and Blue fittings with the 90 degree elbows.
mikehtiger
mikehtiger
Posted: Sun Jan 30, 2011 06:16 AM
I'd love to find some nice braided lines!
I did see this one and thought it was kinda cool too... Thinking about running them like this...
SillyImportRacer
SillyImportRacer
Posted: Sun Jan 30, 2011 08:22 PM
The better way to run switched fans is with a thermostat(sp?). That way the fans come on when needed.
Remember that the roof mount oil cooler is vulnerable to low branches or role overs.
Summit carries braided line land fittings.
Good luck.
crestfallen
crestfallen
Posted: Sun Jan 30, 2011 10:37 PM
My lines are run outside the car and down around the back window
Love the look of the scoops btw. Mine also has a small waterproof (marine) electric fan mounted in it thats wired to a 180 degree thermostat in the oil lines so that it kicks on if the car gets hot (I.E> traffic)
mikehtiger
mikehtiger
Posted: Mon Jan 31, 2011 04:18 PM
Thanks for the pics! I've seen your bug on here a few times... Absolutely Beautiful!!!! Love it!
So I tested my oil cooler, I got for free, by running some compressed air through it and found an unfixable hole... But I threw the cowl and broken cooler on anyway while I search for a new filter.... I figure I'll leave it on for a while to see if I like the look and if so I will buy a new cooler for it.
And of course... PICS!!!
crestfallen
crestfallen
Posted: Mon Jan 31, 2011 07:40 PM
ok now that Ive seen it on the car you HAVE to put it on! Looks sick! Very Happy
mikehtiger
mikehtiger
Posted: Mon Jan 31, 2011 11:48 PM
Thanks!!!
Posted: Tue Feb 01, 2011 01:39 AM
Looks good
mikehtiger
mikehtiger
Posted: Thu Feb 03, 2011 07:44 AM
Allright last time I'm gonna bother you all with this but I have to post a picture with the nerf bars and light bar!
SillyImportRacer
SillyImportRacer
Posted: Thu Feb 03, 2011 12:04 PM
Looks good.
crestfallen
crestfallen
Posted: Thu Feb 03, 2011 06:25 PM
Love it man!
mikehtiger
mikehtiger
Posted: Fri Feb 04, 2011 03:17 AM
Ok... I Lied... Here is the last picture!
No new posts VW Volkswagen & Baja Bug General Discussion Cool VW Bug Roof Rack 0 wideopenmotorsports 2063 Cool VW Bug Roof Rack
 Wed Jun 15, 2016 09:46 PM
No new posts VW Volkswagen & Baja Bug General Discussion I need a roof rack? 5 homeshark66 7259 I need a roof rack?
 Mon Jun 06, 2011 06:53 PM
DustinT3 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Baja roof height with 3x3 setup 3 ghettodish 2826 Baja roof height with ...
 Wed May 18, 2011 05:17 PM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion best way to mount a light bar or roof rack? 7 woodin 11424 best way to mount a li...
 Mon Feb 07, 2011 03:31 AM
woodin View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Roof rack help..
How does your attach?
11 bajaboi727 3492 Roof rack help..
 Mon Oct 11, 2010 08:02 PM
bajaboi727 View latest post
