Visitors: 111
Total: 111
05: Event Calendar
11: Event Calendar
14: Pictures
22: Pictures
32: Pictures
58: Event Calendar
77: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Another new guy with more questions
NAXZ
NAXZ
Post Post subject: Another new guy with more questions
Posted: Sun Jan 31, 2010 06:40 AM
i have one more question......
if i follow the guide from this link
<http://www.bluegrassghostinvestigations.com/baja.htm>
, will the front tires rub someplace if i turn too much? (without stoppers)
im really new to all of this, thats why im investigation a LOT (im the kind of guy that has to have everything PERFECT) lol
also, is there a way to make the back tires stick out a bit more?
note that im in a tight budget here, but i know how to weld a bit, and have access to quit a lot of scrap metal
Post Post subject: Re: Another new guy with more questions
Posted: Sun Jan 31, 2010 08:26 AM
If you going to Baja it you can scrounge up a free or cheap bent beam you can widen it. For a stock fendered Bug you can also just beat the edges of the body and pan flat and live with the noise. This one is 9" wider. Three or four inches should work on your bug.
Some killer tires bought in Mexico.
Posted: Sun Jan 31, 2010 05:26 PM
Also do not use stock VW rims. get a set of the white wagon wheel type rims. You gain from 1" to 1.5" of width per side over the stock VW rims.
NAXZ
NAXZ
Posted: Sun Jan 31, 2010 08:59 PM
i know this might sound a bit dumb, but what are "white wagon wheel type rims"? :$
Posted: Sun Jan 31, 2010 11:54 PM
vindeta
vindeta
Posted: Thu Feb 04, 2010 12:46 AM
nice clean lookin baja james.
perrib....can you like give me those tires? those are freakin awesome..
i need some.
heres my rims...you can see how much farther they stick out than stock rims...
if you compare with perribs rims...
btw these type of rims are officially called "spoke" rims so if you search those you find what you want.
there like $50 new so there nice and cheap.
the stock ones cover up the whole brake drum. mine only cover it about 1/5 inch...you can see almost the whole drum from the front..
Posted: Thu Feb 04, 2010 02:14 AM
btw these type of rims are officially called "spoke" rims so if you search those you find what you want. Smile
"wagon wheel rims" Will pull up a few sites in google for you
Posted: Thu Feb 04, 2010 03:20 AM
thanks,,,just showing,,white spokes,,i have disk in the front,,,,but you can get them in just about any offset you would like!
vindeta
vindeta
Posted: Sun Feb 07, 2010 03:50 AM
those are some hardcore spoke rims man.
vindeta
vindeta
Posted: Sun Feb 07, 2010 03:56 AM
btw on yur question about the tires rubbing. there are two set screws that limit how far the tires can turn. so you can just crank those in a little bit and it will keep your tires from rubbing.
ahha i found the picture i was looking for.
as you can see on the left side of the beam next to the left shock tower. there is that metal tab with a bolt sticking out of it. there is another bolt below it and the arm on the steering box hits those bolts at the limits of it travel. btw my steering box is out right now but it goes just to the right of that tab.
hope that helps....
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 3722 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 4520 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
No new posts VW Volkswagen & Baja Bug General Discussion Tow Bar questions 3 ghs215 1718 Tow Bar questions
 Mon Nov 16, 2015 02:45 PM
No new posts New Members New Guy Questions 6 Apoc 3561 New Guy Questions
 Wed Jun 19, 2013 01:17 AM
Apoc View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Outdoorsman Questions/Outback vs Squareback 10 Grunt-0341 7203 Re: Outdoorsman Questi...
 Sat Oct 27, 2012 07:07 AM
Grunt-0341 View latest post
