Visitors: 106
Total: 106
05: Event Calendar
11: Event Calendar
50: Event Calendar
55: Event Calendar
75: Event Calendar
81: Event Calendar
91: My Account
Baja Forums -:- AzBaja.com Members -:- New Members -:- first baja build
first baja build
matthirsch
matthirsch
Post Post subject: first baja build
Posted: Sat Jan 30, 2010 10:37 PM
hello there, I am new here, I just had my folks bring up their 1967 bug that they are the original owners of.
we decided to build a baja bug this spring.
one question i have is what body kit is the green bug with the rack have on it......
is there a spec sheet on that one??
thanks!!
Posted: Sat Jan 30, 2010 11:25 PM
Welcome to the site! The green car would be Eric- "AzBaja"- the head honcho himself. I'm not real sure what the body setup is on his, actually. Someone will probably chime in. Some of us (my car included) are running one-piece front ends, widened/cut/turned front beams, longer front trailing arms, and longer/wider rear trailing arms. I believe Eric has most of that stuff as well, but I'm not sure of the exact specs. He's also running a Ford Pinto motor in his.
Post up some pics of your project as you go! Wow- a one-owner '67! Are you SURE you wanna cut it up? That's a hard-to-replace pedigree right there!
Enjoy!
matthirsch
matthirsch
Post Post subject: Re: first baja build
Posted: Sun Jan 31, 2010 02:05 AM
yeah, my folks didn't know if they wanted to cut it up, but it's a cali car, so there is almost no rust at all.......
they want something for toolin around back country stuff, and it would be considerably more $$$ to restore it, so we decided to go baja style with it.
it was my first car in high school. here in nevada, you can go wherever you want with a rig like we want to build.
thanks, I like the looks of your ride and the green one too.....
what have you guys spent on your rides???
Posted: Sun Jan 31, 2010 02:44 AM
[quote="matthirsch"]yeah, my folks didn't know if they wanted to cut it up, but it's a cali car, so there is almost no rust at all.......[quote]
Oh man. All the more reason NOT to cut it up. Most of us have had some sort of body damage that helped with the decision. If your's is in that good of shape, I think I'd look for another to make a Baja. IMO.
So with that said, WELCOME!
I have some where between $3-4k tied up in my Baja and I'm running mostly stock stuff.
matthirsch
matthirsch
Posted: Sun Jan 31, 2010 03:31 AM
maybe i will take some pics and post them....you all can give me the advice to either do the baja or not.
there is just a tad of rust inside under the front hood release in front of the gas tank......really nothing to speak of.
there is a little where the storage area is in the back where the back seat folds up against, but very little.
heck, i mean the fenders you can still see the original green paint, and it's shiny and where the side boards bolt on, which is where i have seen every other bug full of rust, there is none that i can see at all....
i will post pics hopfully tomorrow and you all can tell me what I should do.
my mom drove this car for years every day, so if we just restored it, i am sure she would drive it again.
Posted: Sun Jan 31, 2010 03:35 AM
That is a one yr only body,,,mine is a 67,,but it was a baja when i got it,,
Posted: Sun Jan 31, 2010 05:22 PM
Mine was a 67 when I started, every thing has been changed. 67 is not the best year to start with, swing axle rear and joint front end. I'm sure people will chime in more. if not I will ad more on Lunch break tonight.
matthirsch
matthirsch
Posted: Sun Jan 31, 2010 06:45 PM
thank you for the heads up, so should we just restore it to original then??
What year would be best for a baja project???
Posted: Sun Jan 31, 2010 07:06 PM
Well, the "general" consensus is that IRS rear ends and Link Pin front ends are the two most desirable setups (and most modifiable) for offroad use. Unfortunately, NO bugs were ever produced that had both of those. Your year, is the ONLY year produced that had NEITHER! How's that for bum luck? Laughing
No biggie though. The front end (thanks to Bugzyla's bolt on link pin conversion beam, is probably the easiest to change. The frame heads on VW pans, although they look pretty much the same, are different for link pin vs. ball joint. Bugzyla makes an link pin beam that bolts to a ball joint frame head (pan). Traditionally, one has had to cut off the frame head and replace with the desired type to convert a front end.
The rear end of a swingaxle bug ('66- earlier (ish)) can also be converted to IRS. This does take a little bit of welding to install the inboard trailing arm pivot brackets to the torsion housing (pan). A jig is required to ensure proper alignment of the pivot brackets.
So, to summarize, '66 and earlier will give you Link Pin front end, but swingaxle rear end. '68-ish and later will give you IRS rear end, but ball joint front end.
Another thing to consider- many off-roaders prefer the "wide 5" wheel lug pattern over the later-model 4-lug. You can always convert this too, but if it's a factor in your decision, the Link Pin cars had the wide 5 lug pattern already.
Clear as mud? Laughing
Posted: Tue Feb 02, 2010 07:57 AM
I think all cars that have a swing axle rear end have 5 bolt drums. So a 67 Ball joint beam is a 5 bolt drum car. I do not think any VW IRS bug came stock with a 5 bolt drumm, all were 4 bolts. Also VW stock Disc brakes are 4 bolt.
What year would be best for a baja project???[/quote]
Clear as mud? :lol:[/quote]
5 Admin_AzBaja 7342 Baja Bugs on Wiki need...
1568 mufasavnvmc 1020348 Re: what did you do to...
285 MusicManiac 246359 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 469 FREE VW BAJA'S
0 Northmountainauto 1780 Shop Baja
