Visitors: 86
Total: 86
18: Event Calendar
80: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- External roll cage
External roll cage
Buggyboat
Buggyboat
Post Post subject: Re: External roll cage
Posted: Sat Dec 26, 2009 11:28 PM
"If you are so inclined to do so,you should use 120ga tubing and seal the welds air tight-add a small 125 psi air compressor and voila" portable dual function item.--harbor freight has such a compressor, mine fits under the rear bench just fine."
I did this with a tube bumper on a Toyota once. It worked great. You are correct though, there was no way to inspect it. If you think there is an issue, you could tap it with a hammer and listen for a change in the sound.
Thanks for all the info. I did not mean to rile the natives. I was just responding in kind (or at least I thought so). The way it would look never crossed my mind. I drive a 99 Corolla every day to work which ranks much higher on the gay-o-meter than a baja with the cage on the outside. I guess I should have been clear that I was looking for opinions on the technical side. I don't care what it looks like. I have never been a poser and never will be. Thanks for posting the picture and pointing out the strength aspect. I do see how it would not be as strong. I am not building a racer, so it may be ok. If in the end I look gay, at least Obama and Bawny Fwank will be there to protect my rights. Razz
baja62
baja62
Posted: Sun Dec 27, 2009 05:43 AM
Shocked
I have about 20in of travel up front, the rear will have 5x5s and dual shocks the same as the front racerunners. on my exo cage i'm only doing one bar on the side and 2 up the front and down the back. not for rock crawling, but for accessoies and roll over protection becuase how wide my set up is. Just because I know for fact I am going to roll it!!! and so do my friends!! Twisted Evil plus I'M doing an 2.2 ecotec or V6 vtec not sure yet?
longtravel
SCUBASMITTY
SCUBASMITTY
Post Post subject: External roll cage
Posted: Sun Dec 27, 2009 07:33 AM
CARRY ON BROTHER--- CARRY ON !!
out of 100k spermies-I was the fastest !
cyberjaw4
cyberjaw4
Posted: Sun Dec 27, 2009 09:43 AM
i think the only down side to haveing a roll cage on the outside of a car or truck would you could get hung up on a branch or rock where a normal car or truck body woukld just slide right off
Crash
Crash
Posted: Sun Dec 27, 2009 10:29 AM
I had an exo cage on my landcruiser for a while and hated it. It was always in the way and caused so much windage I couldn't get above 60mph on the highway with a V8. I can't imagine what that would do with a air-cooled motor.
Mark
Mark Johnson
Blind Chicken Racing
www.blindchickenracing.com
Buggyboat
Buggyboat
Posted: Sun Dec 27, 2009 06:44 PM
Thanks Mark.
Nothing beats real world expierence. I had not thought about the air resistance. I am ok with a gay looking baja, but a gay looking baja that gets crapy mileage, that is something to think about. Laughing
neadspeed
neadspeed
Posted: Sun Dec 27, 2009 08:00 PM
Mark
the only time i have seen an exso cage is for trail only. I have a huge roof rack on my bug and i have noticed that it like a wind sail
ChuckD
ChuckD
Posted: Mon Jan 04, 2010 09:31 PM
Sorry to interupt, but the noob has a question:
Why pump compressed air into your roll cage? Even while your riding thru the dez your pumping air thru it?
Thanks
Posted: Mon Jan 04, 2010 10:51 PM
Thanks
You use it as a compressed air tank, in lieu of actually carrying one onboard the vehicle with you (since bajas have minimal/nonexistent storage space in many cases). Compressor is optional, as you can "charge" it before each trail run, in case you need it during the trip.
ChuckD
ChuckD
Posted: Tue Jan 05, 2010 05:20 AM
God Damn thats brilliant. Just attach a fitting and you good to go... Thanks az350x
Posted: Tue Jan 05, 2010 10:26 PM
Just make sure you have pilot holes from one tube to the next. It will also show you how good your welds are Twisted Evil
Thanks
ChuckD
ChuckD
Posted: Thu Jan 07, 2010 09:50 AM
[img]www.volksrods.com/forum/picture.php?albumid=93&pictureid=648[/img]
WELL..... If one of you would kindly explain to me how the Hell your supposed to post a picture on here, I would give an example (albeit an odd one) of an external cage bug.
Posted: Thu Jan 07, 2010 04:28 PM
ChuckD wrote:
[img]http://www.volksrods.com/forum/picture.php?albumid=93&pictureid=648[/img]
Most forums won't let you link pics posted in their forum to different sites, which is what you tried to do above. You have to save the pic to your computer, upload it to a free hosting service like Photobucket, and then use the [img] tags and the link to the pic on photobucket to make it show up. It's a bit tedious the first few times, but the cool thing is you can post it to as many places as you like.
NOTE- Once it's uploaded to photobucket, don't move it around from album to album, or the link(s) will be broken and all anyone will see is red 'x's everywhere you posted it.
Photobucket is free, btw.
MusicManiac
MusicManiac
Posted: Thu Jan 07, 2010 10:08 PM
Looks like this one is just a bug body on something else's frame.
I don't like the idea PERSONALLY. Do what you want with your car though! Just make sure to post pics so we can all see your handy work.
Buggyboat
Buggyboat
Posted: Fri Jan 08, 2010 03:36 AM
The orange one looks gay. Smile
25 Kreed 21721 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
18 Dirtjunkie 4474 Official 2016 Hassaymp...
 Tue Nov 08, 2016 03:49 AM
42 wideopenmotorsports 11362 ROLL CALL - HASSAYAMPA
 Sun Nov 08, 2015 04:14 AM
No new posts Events and Get Togethers World Wide ROLL CALL: Hassayampa Play Day 2013 - November 9th & 10th
November 9th & 10th
46 wideopenmotorsports 24317 ROLL CALL: Hassayampa ...
 Tue Nov 12, 2013 10:14 AM
No new posts Events and Get Togethers World Wide Bug-O-Rama Roll Call Sunday 3-25 14 BugZyla.com 6512 Re: Bug-O-Rama Roll Ca...
 Fri Mar 23, 2012 04:04 AM
Ejbbal21 View latest post
