Visitors: 194
Total: 194
22: Home
52: Memberships
58: Event Calendar
98: Event Calendar
107: Event Calendar
122: Event Calendar
123: Event Calendar
124: Event Calendar
125: Event Calendar
130: Event Calendar
145: Event Calendar
150: Baja Forums
157: Baja Forums
158: Baja Forums
162: Baja Forums
165: Event Calendar
166: Baja Forums
171: Event Calendar
172: Event Calendar
178: Baja Forums
179: Event Calendar
180: Event Calendar
181: Event Calendar
182: Event Calendar
183: Event Calendar
184: Event Calendar
185: Event Calendar
186: Baja Forums
187: Event Calendar
188: Event Calendar
190: Event Calendar
191: Event Calendar
192: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- The Crazy Ideas thread
impulsenine
impulsenine
Post Post subject: The Crazy Ideas thread
Posted: Sun Sep 24, 2006 08:15 PM
Hello all,
I would like to hear the unusual customization ideas you have for your Bajas. I have a lot of my own, and I'll share when I see some here. Some moderately wild things are already on the forum - using LineX for the floor covering, custom bumpers and the like. But I'd like to hear some of the really mad ideas, even if they're just pipe dreams so far.
Cheers,
Steve
Post Post subject: Re: The Crazy Ideas thread
Posted: Sun Sep 24, 2006 09:15 PM
All my crazy ideas will remain secret. That way when one of them works right I can make some money on it.
impulsenine
impulsenine
Posted: Sun Sep 24, 2006 10:25 PM
Well you don't have to say HOW you do it, so much as WHAT you're doing...
Bajanick
Bajanick
Posted: Sun Sep 24, 2006 10:29 PM
Boxing in stock arms without pulling them.........LOL
Posted: Sun Sep 24, 2006 10:50 PM
Putting a link pin front end on a ball joint pan without modifing the pan head!!
The craziest idea of all..... thinking someday my Baja will be done!!!!!
impulsenine
impulsenine
Posted: Sun Sep 24, 2006 11:08 PM
Alright, as a few examples:
- Winch mount on both front and back bumpers, and have the ability to put the winch on either side.
- I'm going to be fabricating a swamp cooler whose air intakes are on the hood, and the fiberglass water reservoirs will be down those holes on either side of the trunk. I'll be putting the air ducts into the heater ducts on the corners of the dash.
- Line-X interior with drains. I'm going to try to have basically no upholstery in my car so that I can use a hose to clean my cars' interior.
- I'll be fabricating cubbies and tie-downs to put all my various tools and spare parts in the trunk.
- This weekend I'm going to paint my exhaust header with anti-rust oven paint (good up to 1200 degrees, as opposed to engine paint which is only good up to 300).
Posted: Sun Sep 24, 2006 11:33 PM
Dirt Junkie, I just built a prototype link pin beam that bolts into a balljoint frame head. I will have them for sale soon, in any length you want from stock to 10" wider, and up tp 6 inches norrowed for you ground scrapers. I just dropped the pan on the ground with the beam on it last night, I wil;l take some pics and post the in the next few days.
As far as other wild ideas..... You guys got a few months???
I will say that I have had too many ideas over the years, some have worked, some havnt. My favorite non VW crazy idea is my supercharged Go Ped I built about 7 years ago.
Posted: Sun Sep 24, 2006 11:43 PM
Thanks Daryll Crying or Very sad Ive had that Idea rolling around in my head and on a couple pieces of paper for about a year now, I just dont have the tools to fabricate anything right now. Crying or Very sad I am really interested in seeing your design.
bajasam96
bajasam96
Posted: Mon Sep 25, 2006 12:31 AM
Mine has a link pin frontend using a ball joint head. I just cut m own tubes, not really that involved of an idea
Posted: Mon Sep 25, 2006 12:42 AM
Got pics???????
KrazyKarl
KrazyKarl
Posted: Mon Sep 25, 2006 01:24 AM
" I'm going to be fabricating a swamp cooler whose air intakes are on the hood, and the fiberglass water reservoirs will be down those holes on either side of the trunk. I'll be putting the air ducts into the heater ducts on the corners of the dash."
sorry but can you explain this better, im new to bajas and I have no idea what you are talking about, what is a swamp heater?, why do you need air intakes? what are the air ducks into the heater ducts for?
thanks
bajasam96
bajasam96
Posted: Mon Sep 25, 2006 05:32 AM
I could get ya some pix up later this week if you wanna see
Posted: Mon Sep 25, 2006 03:56 PM
-- This weekend I'm going to paint my exhaust header with anti-rust oven paint (good up to 1200 degrees, as opposed to engine paint which is only good up to 300).
bar b q paint works great!!!! Very Happy
ak_baja
ak_baja
Posted: Tue Sep 26, 2006 02:06 AM
im working on running an external oil cooler in front on the beam with air slots in the nose. Also im putting a sounds system in my car that will blow the pants off all these little ricers running around Twisted Evil . Using the kick panels cut for speakers, speakers in the rear cargo area, amps in the side panels, maybe subs under back seat, also thinking about using fiberglass to mount speakers under the dash, and these for sure but might be replacing the speakers later on www.jcwhitney.com/auto...87/c-10108
Im also thinking of fab'ing mounts for safari doors www.jcwhitney.com/auto...19/c-10108
KrazyKarl
KrazyKarl
Posted: Tue Sep 26, 2006 05:54 AM
it'd be sweet to cut the back off a baja and make a truck right. Then remove the engin but leve the transaxel inplace for the suspension to work. then add a engin and propeler from a air boat (302 ford or 351 chev V8 etc) the weight of the V8 would be near the center of the car, and mounted to the roll cage. Put on wide tyres on the back and skinier sand rail tyres on the front for good steering. The cool thing would be if you could rig up power steering in the front and also to the rudder on the back so you'd have like "quadra steer". I think this would be sweet in the sand. Easy to roll though I should imagen. I drew up a quick pic on paint but i cant figure out how to put them on to here.
Sat November 5th
83 Dirtjunkie 27308 Official 2016 Hassaymp...
 Tue Jan 31, 2017 01:25 AM
No new posts Events and Get Togethers World Wide 2015 Hassayampa Play Day Official Thread
60 wideopenmotorsports 30509 2015 Hassayampa Play D...
 Mon Nov 09, 2015 11:22 PM
16 wideopenmotorsports 8190 2015 Hassayampa Play D...
 Thu May 14, 2015 03:18 AM
No new posts Events and Get Togethers World Wide 2014 Hassayampa Play Day Official Thread
74 wideopenmotorsports 31501 2014 Hassayampa Play D...
 Sun Jan 18, 2015 10:26 AM
No new posts Projects and Builds Build Thread
Baja Karmann Ghia
27 dave46 16394 Build Thread
 Mon May 07, 2012 09:29 AM
