Latest: ddbug11
New Today: 2
Overall: 3596
Visitors: 90
Total: 90
01: Pictures
03: Event Calendar
65: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- One piece window installation..again..PLEASE HELP
The following users give thanks for this topic Anonymous - Sun Apr 26, 2009 12:48 AM
JumpinBruceB
JumpinBruceB
Post Post subject: One piece window installation..again..PLEASE HELP
Posted: Thu Apr 23, 2009 03:08 AM
I know this is an old topic but im at wits end with these things. I just cant seem to get them to fit in anyway. I thought i had the driver in correct and then today i went to roll it down it was off. I assume they are difficult to roll up because of the outer window felt but not sure. My biggest problem is that the window hits the crank part of the regulator on its way down. I know bugzyla said something about some weather stripping had found that worked well. Anyone have any other ideas or bugzyla could you find me that part number please. Thanks guys at this point im thinkning about turning back to original if i cant get them in soon. I can get pictures of what my problem is if needed.
catchbats
catchbats
Posted: Fri Apr 24, 2009 04:24 AM
Is it hitting all the time? It sounds like you don't have the track inside the door adjusted correctly? If they are to far towards the inside of the car it will hit? As far as the weather stripping goes, I pulled mine off like 4 times because the window was so tight rolling up that it was just ripping the clips"not sure what kit you got" out every time you moved it up or down. I eventually got the stripping glued in nice and taped everything and let it bake in the sun for a few days. Then I sprayed the stripping with silicone spray and installed them. It definitely sounds like you have a window tracking issue, did you replace all the felt in the tracks as well? The window should be held by the back one all the time, keeping it from hitting anything.
No new posts VW Volkswagen & Baja Bug General Discussion Looking for a one piece race hood 11 CrisC918 7166 Re: Looking for a one ...
 Tue Feb 03, 2015 09:45 PM
No new posts Projects and Builds One Piece hood 5 PaDan 5179 One Piece hood
 Wed Sep 28, 2011 04:12 PM
No new posts VW Volkswagen & Baja Bug General Discussion where to get and where NOT to get one piece front end?? 6 Poomwah 3794 where to get and where...
 Mon Aug 01, 2011 03:32 AM
Poomwah View latest post
No new posts VW Volkswagen & Baja Bug General Discussion carbon fiber one piece front end 2 jt1957 3119 carbon fiber one piece...
 Mon Jul 11, 2011 09:52 PM
No new posts VW Volkswagen & Baja Bug General Discussion carbon fiber one piece front end 1 jt1957 2578 Re: carbon fiber one p...
 Mon Jul 11, 2011 06:11 PM
