AzBaja Site info
GPS
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Front Shocks?
Front Shocks?
Users browsing this topic:
None
Author |
Message |
PandaBug
Post subject: Front Shocks?
Posted: Thu Sep 11, 2008 10:29 PM
_________________ Wrx Daily Driver\r\nBug Weekends
+34
Post subject: Re: Front Shocks?
Posted: Fri Sep 12, 2008 06:19 AM
That's a really nice looking set-up. Wow! You need to take the bicycle tires off the back soon, though.
To et t up really right, you'd need to measure your suspension at full extension, then measure again at full jounce. Ideally, you'd find a shock that is 1/2" longer that your full extended length, and 1/2" shorter than full retracted length. You probably won't get that close, but make sure your shock doesn't run out of travel when extended or retracted and you'll be safe. I'd look at KYB Gas-A-Just's or even GR-2's (your front end looks light enough for GR-2's). If you want better with stiffer valving, look into Bilsteins. You'll take a beating on the street, but it'll be better in the dirt.
There's a lot of info out there about valving, spring weight, travel, etc. You can really get technical if you're interested, but after that, I think you'll find yourself going in a similar direction to what I was suggesting.
You might talk to BugZ on this. He can probably look at this picture and rattle off a part number for you to investigate.
Nice job on the bug, I really like it.
"Kaddie Shack" Air-cooled VW Parts and Service Specialists Shoot me an email if you need a price on something specific you're looking for that you don't see. We probably handle it!
PandaBug
+16
Posted: Sat Sep 13, 2008 12:20 AM
can not tell, but is that an ex race car?
PandaBug
+16
Posted: Sat Sep 13, 2008 12:46 AM
So I'm thinking it once had coilovers on the front/maybe...That would be cool.
PandaBug
Posted: Sat Sep 13, 2008 01:01 AM
I am pretty sure it did, I am already over spent on parts so I can't afford coilovers with reservoir so I am going to wait on those for later on, unless someone almost wants to give them for free to me, you never know!
+28
Posted: Sat Sep 13, 2008 01:59 AM
So, are you running torsions in the front now, or is there something holding the front end up that we can't see in the pics?
Keep in mind that most likely your limitation on rear travel isn't going to be shock mount location, but axle angle (CV angle) at full droop and full compress- most likely full droop will be the issue.
PandaBug
Posted: Sun Sep 14, 2008 01:17 AM
Yeah I am running torsions, Yeah I know, I have pretty much the same set up you have in the back, 930 CVs 3x3, rear discs. How do you like it? What kind of shocks are you running in the back?
+28
Posted: Sun Sep 14, 2008 01:28 AM
PandaBug wrote: |
Yeah I am running torsions, Yeah I know, I have pretty much the same set up you have in the back, 930 CVs 3x3, rear discs. How do you like it? What kind of shocks are you running in the back? |
Right now, I'm not running anything.  I had some Empi-ish disk brakes and boxed 3x3 rear arms on the car when I bought it, and no front brakes at all. The rear shocks were just big long nothin-specials. I'm somewhere in the middle of a brake upgrade and some suspension upgrades as well right now. Someday (God-willin' and the creek don't rise), I'll finish the project. It will then be Chenowth chromoly tubular 3x3s (already on), SACO 4-wheel cross-drilled disk brakes with Wilwood calipers (4-piston rear, 2-piston front- in the garage, not yet on the car), and Pro-Comp 10" and 12" shocks with external reservoirs (also in garage, not on car yet). Also adding 6-over Warrior beam, Tweed's 2 1/2x1 chromoly arms (on car), and SACO rack and pinion steering.
Sheesh. It sounds like a big project when I lay it all out like that again. No wonder it's taken since April!
PandaBug
Posted: Sun Sep 14, 2008 09:31 PM
Sounds like a projct, I have all my parts inside of the car, caged and the engine is still in the box in pieces, I am just buying everything so I can just put everything together at once, I am running some disc brakes too that came with the 3x3's I bought, Still looking at what I want the final project to look like. It is a big project but, i'm sure i can do it.
Picture Box
Great things to Buy
Other Sites
Parts - For your Car
