Latest: Curtis
Overall: 3613
Visitors: 145
Total: 145
07: Home
12: Event Calendar
14: Home
15: Event Calendar
19: Links
31: Event Calendar
37: Home
58: Home
62: My Account
67: Event Calendar
68: Home
91: Event Calendar
98: Event Calendar
101: Home
129: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Gotta rail buggy....
meangreen
meangreen
Post Post subject: Gotta rail buggy....
Posted: Tue May 06, 2008 04:48 AM
traded some junk for a rail buggy,that has turned out to be more of a pain than it mite be worth,first things first....i had the day off today so i got the rail home,then took a good hard look at it and decided that it looked to short,81" wheelbase to be exact,so i stretched the front 24" wich made it look ALOT better,then i desided that the back looked retarted as in half way down the rear hoop there was a bar that ran down and conected halfway between the hoop and the rear of the cage if that makes any sence at all but anyway i cut that out and welded bars that run from the top of the hoop,or roll bar....and ran to the back of the cage more like the rails u tipicly see.so after that was done i decided that the arch of the roof bars just didn't "flow" with the rest of the rail....so i cut them out and ran flat bars from the front hoop or windshield bar to the rear hoop.so now what i have is a rail that i am happy with for the time being.with gas getn so high these days i am gunna start driv'n this lil' dude....just need a front glass,wire it up and get some lights along with a new clutch and i'll be set.
meangreen
meangreen
Post Post subject: Re: Gotta rail buggy....
Posted: Tue May 06, 2008 06:15 AM
i am trying to figure out what i wanna use as a gas tank i am thinking an air tank,has anyone ever done this ? but i dont know what size would be apropriat becuz i couldn even ballpark how it'l be on fuel what do ya'll think.....750pound'ish buggy with stok 1600 engine stok swing axle tranny and 235/75-15 all around.....how should i wire it up ? a kit or just wing it ? what type lights would yall suggest ?
Posted: Tue May 06, 2008 07:06 AM
You can get a boat fuel tank from a marine store, and it will have a fuel sending unit installed already. Mine is 12 gallon and has a standard GM 90 ohm sender. Run one wire to a matching gauge and run a ground for the tank. You're done. No need for a kit.
Lights are a different subject all together. My advice would be different, depending on how many you are planning to run... 2, 4, 6 or 8. Lights are designed to do different things. Here's how I would do them (in this order):
Standard headlights are designed to (of course) illuminate the road ahead of you, casting a slight beam upward toward the passenger's side (to illuminate street signs), and keep the top of the beam lower than the drivers in the cars ahead of you. They are also designed to cut off the light toward the driver's side so you don't screw with oncoming traffic.
Driving lights are somewhat like headlights, but tend to me more of an pattern. They will generally illuminate a bit more to the sides, and a a little further than headlights. This is a good all-around choice for a second set of lights.
Fog lights (true fog lights) emit a narrow but WIDE beam. If the lights are installed low and forward in your vehicle, and aimed parallel to the ground, the work AWESOME as a third set of lights for an off-road car. They are really handy when speeding along narrow dirt roads at night, because they illuminate the sides of the road really well and you can see the turns coming much better than either one of the previous two.
Off road lights, if you absolutely must have them, are often made to cast an extremely narrow and long beam. They will work exceptionally well if you are driving on a perfectly straight trail at night, and you want to illuminate way out in front of you. Mount them high, and you'll get the best results. They give you a weird feeling if you drive only with them on while in the dirt at night, as they give you the feeling that they illuminate behind the direction you're turning, if that makes sense. They sell well, look cool, and make wads of money for off road outlets; but they would actually be my last choice for lighting that works. I'd run them if I was going to run 8, and I've run them in the past.
Them're my thoughts.
Staff Officers
Posted: Tue May 06, 2008 10:56 AM
Off-Road Lights...
You have Spots and Floods
Flood lights are great mount them high up and you will love them. Spots are another animal, high on the cool factor but I still love the floods for night driving. Going up and down hills give you some real strang feelings when useing spots too. From making a little dip look like a huge hole to the road goes away on a hill has the lights are now pointed into the hill than up it. Go for the Floods and you will love them.
tucsontim
tucsontim
Posted: Tue May 06, 2008 03:38 PM
I picked up a set of buckets for a 7" sealed beam,
a conversion kit for sealed beam to H4,
and a conversion kit from H4 to HID.
The result:
17degree HID spots.
At 100 feet from the car, two of these illuminate a pattern 50 feet wide and 30 feet tall...quite brightly.
1569 mufasavnvmc 1175130 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
No new posts Projects and Builds Old school-ish budget buggy 7 pepeazul 7116 Old school-ish budget ...
 Fri Jul 17, 2015 02:29 PM
34 ghettodish 24359 Buggy
 Thu Aug 22, 2013 08:34 AM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion My VW Rail vacation 13 azdesertrat87 8479 Re: My VW Rail vacatio...
 Mon Jul 22, 2013 07:32 PM
No new posts VW Volkswagen & Baja Bug General Discussion My Hi Jumper Buggy 14 MojaveRacer208 25611 Re: My Hi Jumper Buggy
 Sat May 11, 2013 07:08 PM
Wheel_Works View latest post
