Visitors: 160
Total: 160
07: Event Calendar
23: Event Calendar
33: My Account
73: Event Calendar
86: Event Calendar
89: Event Calendar
90: Event Calendar
121: Event Calendar
124: Event Calendar
144: Event Calendar
145: Event Calendar
158: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- My baja bug project rear end question ?
Post Post subject: Re: My baja bug project rear end question ?
Posted: Fri Nov 02, 2007 05:44 AM
Does the 19.25 axle bind when at full plunge(level axle)?
Posted: Fri Nov 02, 2007 06:56 AM
I think I know what the problem is. When you order the axles for 3x3 arms the motor and tranny is usually an 1 1/2 to 2" forward the motor and tranny in the car are moved back to the rear 2" this was done to cut down on multiple angles on the cv joints. When I originally figured out the axle length it was 18 3/4" roughly. I was going to have axles made up by gear one in phoenix. I think that would take care of the problem if you had the axles that are 19 1/4 machined down.
DRUMMOND
DRUMMOND
Posted: Fri Nov 02, 2007 07:00 AM
It didn't at first but I closed up the himes some and now it clears but I don't know about the toe now. I got sidetraked on the travel problem.
How much travel should I have with this setup ?
Duane Drummond
DRUMMOND RACING
PRO SEATZ
www.proseatz.com
DRUMMOND
DRUMMOND
Posted: Fri Nov 02, 2007 07:07 AM
Hey Whats up? how did the bbq go I wanted to be done in time.
could not make it.. Wont miss the next one !!!
That is the only reason that I could come up with for the axles being shorter you can see the 2in block in the photo.
Thank you for confirming that..
I just cant figure out why I cant get the travel...
Really looking forward to hanging with you guys!
Duane Drummond
DRUMMOND RACING
PRO SEATZ
www.proseatz.com
5 Admin_AzBaja 6782 Baja Bugs on Wiki need...
1568 mufasavnvmc 999136 Re: what did you do to...
285 MusicManiac 241309 Re: Baja sightings
1199 Dalton 338581 My 69 project
