Visitors: 130
Total: 130
01: Pictures
43: Pictures
87: Event Calendar
91: Pictures
100: Home
113: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Pan Swap...anything I should know
MWDesigns
MWDesigns
Post Post subject: Pan Swap...anything I should know
Posted: Tue Oct 23, 2007 11:56 PM
Hey guys,
Ok I think I finally decided to suck it up and swap out the pan on my '69.
I think the pan I got is a '73 according to what I found from the serial number.
I talked to BugZyla a little about it at Bugtoberfest.
The question, is there anything i should know or look out for before I begin?
I plan to clean up the donor pan and bed line it while it's all apart. The '69 pan has the double spring plates and BugZyla told me it's no problem to swap them out to the donor. How can I tell which torsion bars are better to use? i.e. the ones in the donor or the ones in the car now.
Thanks for any help or tips you guys have for me Very Happy
P.S. FYI the reason for the swap is the pivot bolt "nut" in the current pan has been ripped out.
www.michaelwhitedesigns.com
Graphic Designer,
Independent Amsoil Dealer
www.mwlubricants.com/
Army OIF Veteran
and general desert rat
'69 SLOOOW going project
Post Post subject: Re: Pan Swap...anything I should know
Posted: Wed Oct 24, 2007 04:33 PM
The only way to tell the difference in the torsion bars is to measure them. Both cars should have the long bars, ~26 9/16" which give a better ride. The only other thing to look at is the diameter. Stock is ~22 mm. Depending on setup, you would probably want to go thicker.
Posted: Wed Oct 24, 2007 09:00 PM
I found out the hard way that the torsion tube on a pan I picked up with my car was bent. It had a bow in it between the shock towers, I had just widened the front beam and was bent down looking at that plane and noticed the rear torsion was not on the same plane.
I am not saying yours is bent but it is something to watch out for, this car was raced and without the proper cage support all the weight pushed the center towards the ground......
MWDesigns
MWDesigns
Posted: Wed Oct 24, 2007 10:56 PM
kncaz Thanks
I wouldn't have thought of that. I know the car I got the donor pan from was used as a parking curb for a buddies rock crawler. The whole roof was caved in Confused ... So I think it might be a good idea for mr to look into seeing if the tubes are bent.
Graphic Designer,
Army OIF Veteran
MWDesigns
MWDesigns
Posted: Sun Nov 11, 2007 05:00 AM
Today I cut the seat humps off and I'm looking for any ideas to quickly and easily remove the rust and crap off of the pan. All of the tar insulation is gone. (already gone when I got the pan) I don't even think it had any. There aren't any signs of there being any.
Graphic Designer,
Army OIF Veteran
StinkBug333
StinkBug333
Posted: Sun Nov 11, 2007 06:06 AM
i used one of those wire cups from the Harbour Freight on my grinder for the pan. Use it for just about everything...
If your gonna be Dumb
YOU BETTER BE TUFF!
MWDesigns
MWDesigns
Posted: Sun Nov 11, 2007 06:58 AM
I have a small one for my pneumatic angle grinder, but I only have a small 2Gal air compressor and it wont keep up. do they make one for an electric grinder I have one of those. (from harbor freight) That is what I used to cut the humps off with.
Graphic Designer,
Army OIF Veteran
Posted: Sun Nov 11, 2007 03:09 PM
Yes go to KENT's tools on Grant and Stone................he has everything.
Posted: Sun Nov 11, 2007 10:31 PM
[/quote]
KC, what do you have your level sitting on, and is it a four foot level ?
Posted: Sun Nov 11, 2007 11:10 PM
4 foot level sitting on cast body mounts in the shock tower. This pan has long been covered up at the local dump.
No new posts Projects and Builds Toyota 3tc swap
Baja bug toyota swap
14 Sandrailbuilder 9113 Re: Toyota 3tc swap
 Wed Apr 18, 2018 10:21 PM
6 AZOffroadSwapmeet 3645 AZ Off-Road Swap Meet
 Fri Dec 09, 2016 02:37 PM
5 bajabuggy69 4797 Rebuild and engine swa...
 Fri Sep 05, 2014 06:23 AM
spheromike View latest post
No new posts VW Volkswagen & Baja Bug General Discussion VW TDI Engine swap? 8 Grunt-0341 6401 VW TDI Engine swap?
 Thu May 02, 2013 01:06 PM
blg4351 View latest post
No new posts Events and Get Togethers World Wide Michigan Buggy Builders Swap Meet 0 Lucky7-11 2709 Michigan Buggy Builder...
 Fri Feb 01, 2013 02:45 AM
Lucky7-11 View latest post
