Visitors: 145
Total: 145
31: Event Calendar
35: Pictures
54: Home
63: Home
97: Pictures
110: My Account
113: Event Calendar
136: Home
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- 72 baja
72 baja
gman3850
Colonel
Colonel
gman3850
Post Post subject: 72 baja
Posted: Thu Jun 04, 2015 10:59 PM
well dont know what happened to all my other pictures in my other thread so i thought ide start a new one. Also decided after hearing alot of low offers for it i decided to keep the bug and get her running so if wanted it can daily drive without problems
this is from a couple a weeks ago, Drove around 50 miles in 4peaks area and in butcher Jones and ended up breaking a brake line and steering was really bad.
and how she shit now
dont know why i am getting corrosion
and dont thing this is suppose to be bent time for skid
after a few hours of wire wheeling and dying
decided just to paint the pans for now instead of welding in spots. If going to weld just going to replace
couple cans of undercoat.
hopefully Friday or Saturday i am going to pick up a complete thing beam and complete rear suspension from a 1974 thing. So i might be in need of some 5 lug rims if i dont reuse the 4 lug drums from the bug
Posted: Fri Jun 05, 2015 02:23 AM
Looking Great!
gman3850
Colonel
Colonel
gman3850
Post Post subject: Re: 72 baja
Posted: Fri Jun 05, 2015 10:36 PM
got the sound deadning in place.
90 out and 50% humity is making it very hot inside bug, probly lost 5 lbs in water haha
vwboat
vwboat
Posted: Sat Jun 06, 2015 04:21 PM
WHAT DID YOU USE TO DO THE INSIDE AND PANS? wHERE DID YOU GET IT?
lOOKS REAL GOOD.
vwboat(JOHN)
gman3850
Colonel
Colonel
gman3850
Posted: Sat Jun 06, 2015 05:04 PM
Well I used 2 different products. I had 2 rolls of quick roof left from when I did my daily. I like working with stuff. About 25$ a roll. Ran out of that so went to lowes and got there product called peal and seal. This product was thinner and was more difficult to work with. 35$ for 2 rolls. If I did again IDE probly do all quick roof. If on a budget the peal and seal will do fine and u can almost get 6 rolls for the price of 4 rolls of quick roof.
vwboat
vwboat
Posted: Sat Jun 06, 2015 06:21 PM
Thanks, That's what I thought it was. Have not been able to find at home Depot yet.
John
gman3850
Colonel
Colonel
gman3850
Posted: Wed Jun 17, 2015 09:01 AM
got a couple things done.
got the rear wiring all done just not in car yet. also built the back shelf. and got the front door panels done
got to rep for the azbaja haha
also got the hard start relay in, jot need to make ground wire
Posted: Wed Jun 17, 2015 05:49 PM
Just a heads up, your amp might overheat itself with no air flow to it. Mine was mounted in the open and would overheat until I put spacers under it to let air flow around it
gman3850
Colonel
Colonel
gman3850
Posted: Wed Jun 17, 2015 06:00 PM
There is airflow from the the side of the box. That is why I mounted it so close to driver side. The rear deck leaves about 2" of space between the rear panels and the deck.
Posted: Fri Jul 17, 2015 02:41 PM
Lot of work to clean a Dirty Windshield, I think I would of gone with the garden hose myself. Smile
5 Admin_AzBaja 6857 Baja Bugs on Wiki need...
1568 mufasavnvmc 1001458 Re: what did you do to...
285 MusicManiac 241868 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 62 FREE VW BAJA'S
0 Northmountainauto 1561 Shop Baja
