Latest: bajaman_69
Overall: 3595
Visitors: 124
Total: 124
06: Text Menu
13: Contact Admin
22: Pictures
34: Pictures
59: Event Calendar
98: Contact Admin
101: Event Calendar
113: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Class 11 PepeAzul
Class 11 PepeAzul
pepeazul
pepeazul
Post Post subject: Class 11 PepeAzul
Posted: Tue May 19, 2015 02:38 AM
Not exactly a build thread, but I came across these pics as I was looking for other stuff and thought someone may want to see these... Mockup of the rear shock and the final rear arm shock mount.
azdesertrat87
azdesertrat87
Posted: Tue May 19, 2015 06:45 PM
I've never seen a horizontal bump stop could you please explain is use thanks also is that the upper shock mount ( tempurarly ) held on with a u bolt ?
Last edited by azdesertrat87 on Tue May 19, 2015 06:48 PM; edited 1 times in total
PepeazulGreg
PepeazulGreg
Post Post subject: Re: Class 11 PepeAzul
Posted: Tue May 19, 2015 06:50 PM
at the top of travel the red bump stop hits the arm mount (the flat spot)... this limits the upward travel so the tire does not hit the top of the wheel well... our tires are over sized so they do rub when we hit the top of travel but in theory a stock rim and tire would not hit the top of the wheel well
www.pepeazul.com Home of the Rustoleum blue bug.
Posted: Fri Jul 17, 2015 02:29 PM
Like the Bump stop.
25 Kreed 27662 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 5569 New Class 11 Build - P...
60 wideopenmotorsports 49215 CLASS 5 Resurrection!
 Mon Feb 22, 2016 06:23 PM
No new posts VW Volkswagen & Baja Bug General Discussion 5-1600 vs Class 11 Version 3 2 wideopenmotorsports 3642 5-1600 vs Class 11 Ver...
 Thu Oct 08, 2015 08:12 PM
No new posts Projects and Builds class 5 baja bug needs motor... 0 Azbugracing1214 3132 class 5 baja bug needs...
 Tue Jun 09, 2015 12:51 AM
