Visitors: 92
Total: 92
21: Event Calendar
50: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Vintage race junk donated it's parts 4 my desert toy.
Azdrtdog
Azdrtdog
Post Post subject: Re: Vintage race junk donated it's parts 4 my desert toy.
Posted: Mon Jun 01, 2015 07:47 PM
I think I'll need to change my spring rate and ad a shim
Or 2 to the valving, those arms crush my springs right now. I have the arms on and I ended up using 2 shims on the outside of links and the inside at bottom for thrust wear,and tightening down bottom links I measured actual gap I had at the top link and added the correct amount of shims to fill the gap so I know my links have zero bind, I just finished lengthening my tie rods 2" so I can set toe then I will be able to set camber. C/k sounds good let me know
Picked some hardware up today and the +2 tie rods I mocked up fit perfect, I set the toe and camber looked fine. Went for test ride last night and it drove str8 and gr8, I can't wait to see how it feels in the desert. Ended up putting the #350 springs back on, they feel more linear with less preload
Changed springs, bearing service new seals. Cycles 14" tie rod limited
Azdrtdog
Azdrtdog
Post Post subject: Vintage race junk donated it's parts 4 my desert toy.
Posted: Mon Jun 15, 2015 01:21 PM
Took it up to crown king over the weekend, I will have to revalve the shocks or or try a 20wt oil. Ride was good but needed way more valving
Azdrtdog
Azdrtdog
Posted: Sun Jul 05, 2015 04:42 PM
Mounted up some new shoes, can't wait to chunk em up
gman3850
Colonel
Colonel
gman3850
Posted: Sun Jul 05, 2015 05:05 PM
Km2 are nice tires. Did u just pick those up from Craigslist? If so u got a dam good deal on those. I was trying to get them as well
Azdrtdog
Azdrtdog
Posted: Sun Jul 05, 2015 05:12 PM
No I paid full price from discount
Posted: Mon Jul 06, 2015 02:18 AM
I love discount's road hazard.. cant bring the rail to them... they wont touch it.. but they have replaced a few of my KM2..
Azdrtdog
Azdrtdog
Posted: Mon Jul 06, 2015 03:53 AM
I didn't get the certs this time, they won't touch bead locks and in the past I've had them tell me no vehicle no warranty so I didn't want to go through the bs and waste the money. Use to be $20 you would get a new tire and no bs but I've heard they measure tread depth now and only warranty the usable tread left and I would have to take the tire down loose with waffle marks on the bead. Every store is different but I've heard from other guys there getting more difficult with the off road stuff
gman3850
Colonel
Colonel
gman3850
Posted: Mon Jul 06, 2015 04:12 AM
That is why I like the bigotries brand tires. Have had them on a couple trucks and my buddies jeep. My buddy trashed 2 tires in one trip and brought them in and the replaced them right than and there
Azdrtdog
Azdrtdog
Posted: Mon Jul 06, 2015 04:20 AM
So far I've been lucky, (knock on wood) my rear rims
are 4.5" wide so it keeps the side walls pulled in and I haven't punctured a side wall so far, just tread plugs
Posted: Tue Jul 07, 2015 01:52 AM
I never tell discount anything. I bring them the rims and pic them up later. They don't need to know what they are put on, they just need to honor the warranty.
We have actually thrashed BFG and TOYO tires at races. Drop them off an pick them up later. Just need to buy the certificates on initial purchase.
Azdrtdog
Azdrtdog
Posted: Tue Jul 07, 2015 01:57 AM
They don't touch bead locks, all I can take them is a loose tire
Posted: Tue Jul 07, 2015 02:30 AM
you are right!!! I don't tell them anything.. I have kicked out of 3 stores so far for opening my mouth.. if they push it I tell them it is on my "street Baja" and if they ask why I did not bring in the car I tell them I did not want to wait for them to fix the tire. last year the manager pushed me a little so I drove my yellow Baja in to show him ... he said he could not work on the car at all because I use adapters and I would always need to bring the tire in loose.. he has never asked me again. Cool
Azdrtdog
Azdrtdog
Posted: Mon Jul 13, 2015 03:17 PM
Finally got the last of the 4 to 5wide adapters off my car this weekend, installed some latest rage wide 5 discs out back and gave my buddy the 4 lug discs for his car that he desperately needed to get rid of his drums. Now I just need to get disc back up front again since I swapped to combos I had to go back to drums up front till I can afford the discs for them, still stops decent and if it doesn't I'll just borrow some stopping power from the guy in front of me lol
Posted: Tue Jul 14, 2015 03:02 AM
it is a good off road combo ... using disks in the back and drums in the front.. a lot of people set it up this way so they don't need a proportion system in there car. I ran my first rail that way for years and loved it. I used a sander on the break shoes to trim them down so the front tires did not lock up first. work great!
Azdrtdog
Azdrtdog
Posted: Tue Jul 14, 2015 01:16 PM
I already have the bias valve next to my shifter, and I have the pedal assembly with it that I got from the other car I plan on using later on. I don't like the maintenance that comes with drums, I had to adjust them up already just getting the rust burned off and the shoes seated
No new posts VW Volkswagen & Baja Bug General Discussion Looking for a one piece race hood 11 CrisC918 5878 Re: Looking for a one ...
 Tue Feb 03, 2015 09:45 PM
No new posts New Members New Member who loves the desert
69' Baja Bug
3 spheromike 2628 New Member who loves t...
 Mon Sep 08, 2014 06:09 AM
No new posts New Members An Arizona Desert Rat 1 t.goodman58 1681 An Arizona Desert Rat
 Thu Jan 23, 2014 04:13 AM
49 wideopenmotorsports 26866 Pit Help Needed For Of...
 Tue Jan 08, 2013 06:07 AM
No new posts Projects and Builds Chirco parts 9 dutchsubdriver 4142 Re: Chirco parts
 Wed Nov 21, 2012 03:40 AM
