Latest: rcwtony
Overall: 3607
Visitors: 96
Total: 96
05: Home
11: Home
12: Event Calendar
24: Event Calendar
31: Event Calendar
74: Event Calendar
Baja Forums -:- AzBaja.com Members -:- New Members -:- Thinking about a Baja Bug project, need advice.
NoKnowledgeCollegKid
Post Post subject: Thinking about a Baja Bug project, need advice.
Posted: Thu Mar 05, 2015 10:23 PM
Hey everyone, so I have never owned a bug before, nor had I ever thought about owning a bug before this year when I began looking into Baja Bugs. I have virtually no knowledge on what I should look for when I go to buy my bug, so that's why I came here.
I'm looking for any and every piece of advice yall can give me on these majestic machines. What year model I should look for, what kind of condition it should be in for what price, the size of the engine bay (so I can start looking at possible engine options), etc.
Anything helps, thanks guys.
yellowchev
yellowchev
Post Post subject: Re: Thinking about a Baja Bug project, need advice.
Posted: Fri Mar 06, 2015 07:05 PM
I was actually going to post a similar question, but since you did I'll just piggy back on your thread!
Posted: Fri Mar 06, 2015 09:44 PM
Need to begin with your vehicles purpose. Street, dirt, street and dirt. Trails slow or rough roads fast. Big budget or little. Region: desert, sandy, forests etc. The options are never ending.
Posted: Sat Mar 07, 2015 01:40 AM
in my world ... my "Options" are limited my wallet.
so I build what I can afford and spend wisely... Very Happy
yellowchev
yellowchev
Posted: Sat Mar 07, 2015 02:38 AM
IVe got a pretty good idea for mine. Mostly street but off road forest trails to camping/hunting/fishing destinations. I guess my question is how do I teach myself about VWs and exploring the endless options you mentioned. How do I learn to know what to consider and look for such as body conditions and the different parts to inspect such as the pan, trans, engine, etc.? im thinkin a 67-69 for model year. Don't know why other than I read something that those years are great for working on.
Posted: Sat Mar 07, 2015 03:21 PM
69 - 79 beam car are the best. not the super beetle (unless you put a ball joint beam on them.... then they are the best.)
I would start with...
can you perform your own fab? welding? Bender? or do you have deep pockets to pay someone else to do the work for you?
Posted: Sat Mar 07, 2015 03:30 PM
Pocatello... you guys have a lot of that "green stuff" and lots of "white stuff " in winter.. lot of flat lands with steep hills with thick mud.
if you are going to stay "air cooled" you will need an .002 trans. big 33x10.50 tires.
Posted: Sat Mar 07, 2015 08:30 PM
If you are going with a baja that is mainly street with some fire roads and easy to navigate trails then it doesn't matter too much what year you buy. Try to stick to a basic baja with the VW aircooled motor, fiberglass body kit and some slightly bigger tires.
Too many people get caught up in the newest and latest trends to add to a VW. The basic baja has been around for years and will continue to survive in the future.
Unless your into elaborate engine swaps and have the skill to do the swap, just keep it simple and enjoy your car. Learn as you go and add things as time and money allow.
Too many projects start off with great new ideas on how to reinvent the wheel and then end upon craigslist as a project for sale.
Simple, easy, maintainable...
yellowchev
yellowchev
Posted: Sat Mar 07, 2015 11:12 PM
Thanks guys this is good stuff. I'm all about keeping it simple and not going full speed just to turn around and sell the 'project car.' I just ordered some manuals ( "how to beep you VW alive, "Bugs and Buggies", and I'm looking at "how to rebuild your vw aircooled engine" by Tom Wilson) so I can familiarize myself with the terms, parts, etc. Any advice on increasing the depth of my pockets? Wink any other suggestions?
W.O.M.S.- thanks for the "keep it simple" advice. I want to get into this like you said as time, money, and learning permit. Just like the idea of having something to tinker on.
Dalton- what's a "beam car"? What do you mean by "green stuff"?;) I was planning on aircooled because I figured that was all vw made for the bug? Do they make a water or liquid cooled engine? What is a .002 trans? Transaxle?Transmission? What does the .002 stand for? Sorry for all the questions. I'm ignorant to all of this. Ps I looked at you restore pics. Very detailed. Definitely will be referencing those in the future.
Posted: Sun Mar 08, 2015 03:18 AM
This has been super helpful so far actually. I plan on building the bug mainly for street use and some off roading but the eventual goal is to build it into something that can handle the Baja 1000 but that is a decade down the road. I do wanna try to either turbo the engine or do a swap eventually just due to the fact that 59 hp isn't gonna cut it for me. I have some experience welding, fabbing, etc. so that isn't an issue but the issue for me is what should I look for when I go to buy my bug so I don't overlook something and end up with a major problem a couple hundred miles after getting the thing.
Posted: Sun Mar 08, 2015 03:48 AM
well here what I think I know....
Transaxles:
Swing axle from the first bug tell 1968ish - simple, not super good on street when you jack them up.
IRS type 1 - from 1968 - till the end of the bugs. simple, much better ride on and off road, upgradable with bolt on parts. I think there are 3 different ring gears for them. (the lower the ring gear the bigger the tire you can pull)
IRS type 2 (bus transaxle) there are 3 I know of ... strong. low gears, so you can get the most of a small motor.
part number .002 the lowest gears.
the Pirmit bus transaxle -- don't know much about them other than they are hard to find.. (I think not worth looking for)
Part number .091 strong gears tall ring gear. if stock can handle up to 150HP ... for little money can be beefed up to 200hp.
the trans on the left is an .002 bus box and the right is a type 1 (car IRS trans)
Posted: Sun Mar 08, 2015 03:54 AM
the 2 trans on the left are .091 they have 6 ribs over the diff.
the trans on the right is an .002 they have 3 ribs over the diff.
Posted: Sun Mar 08, 2015 03:56 AM
bus is better.
Posted: Sun Mar 08, 2015 04:03 AM
the front:
just talking about bugs
1950ish - 1967ish - has a "king pin" beam, simple but the spindles are week.
1967ish - 1979ish - has a "ball joint" beam, strong if maintained
1972ish?? - 1979ish - supper beetle - has a McPherson strut front end.. not very good off road.
Posted: Sun Mar 08, 2015 04:07 AM
this is a ball joint beam.
5 Admin_AzBaja 10431 Baja Bugs on Wiki need...
1569 mufasavnvmc 1145824 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
285 MusicManiac 276752 Re: Baja sightings
103 SuburbanLegend 159217 Carbon Footprint...aka...
 Tue Sep 03, 2019 03:15 AM
Mykul View latest post
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 2821 FREE VW BAJA'S
