Latest: Curtis
Overall: 3613
Visitors: 110
Total: 110
07: Event Calendar
21: Event Calendar
23: Event Calendar
50: Event Calendar
53: Event Calendar
56: Pictures
58: Event Calendar
64: Pictures
72: Home
73: Home
76: Event Calendar
79: Event Calendar
87: Home
110: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Center Mount Fan Shroud
Darn_Near
Darn_Near
Post Post subject: Center Mount Fan Shroud
Posted: Sun Mar 30, 2014 09:12 PM
Is there any Disadvantage or Advantage to running a Center Mount Fan shroud on a Street Baja (no heater)? '69 1835cc .009 Dual 40's. I just like the looks but can only find one source, back in the late 70's they were every where. I ran them on my sand rails/buggies with no problems, but have not ran them on a street bodied Baja. I was just curious as to why they have disappeared from the scene.
Measure it with a micrometer
Mark it with chalk
Cut it with an AX
Beat it together
Put VW on it
DRIVE THE SNOT out of it!
Tyler
Tyler
Posted: Sun Mar 30, 2014 09:53 PM
From what I've read, the aftermarket shrouds (or tin for that matter) do not cool as well as the OEM.
Just what I've read. I remember the sandrail I built with my father when I was a kid had no issue running hot with an aftermarket shroud.
Being so... I have a stock 36hp shroud and external cooler on my baja now.
Posted: Wed Apr 09, 2014 05:47 AM
Yeah, the consensus back then was that while such fan shrouds seemed cool, they really didn't perform as well as a good ol' 36hp fan shroud. And they were often heavier. All this does not mean they are BAD. Just not any better. For a center mount, you need the generator stand casting as well as the shroud.
TINMAN
TINMAN
Post Post subject: Re: Center Mount Fan Shroud
Posted: Thu Apr 10, 2014 04:18 PM
you also must run a external oil cooler with a center mount ,no big deal on a baja.
TRUMP 2020
ghettodish
ghettodish
Posted: Sat Apr 12, 2014 05:13 AM
Is this the one you found?
vwparts.aircooled.net/.../11001.htm
edit:
never mind... it just dawned on me...
You meant this one, right?
www2.cip1.com/ProductD...e=C12-4521
No new posts VW Volkswagen & Baja Bug General Discussion dellorto 36 center mount 2 _-Mad-Max-_ 3245 Re: dellorto 36 center...
 Tue Jun 19, 2012 03:38 PM
No new posts VW Volkswagen & Baja Bug General Discussion best way to mount a light bar or roof rack? 7 woodin 15130 best way to mount a li...
 Mon Feb 07, 2011 03:31 AM
woodin View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Fabbed new plate mount and light 9 Tcatdrv 5067 Fabbed new plate mount...
 Sun Jul 04, 2010 07:41 PM
Tcatdrv View latest post
No new posts VW Volkswagen & Baja Bug General Discussion cut the center beam 1 1969Type1BAJA 2049 Re: cut the center bea...
 Sun Dec 06, 2009 09:33 PM
No new posts Projects and Builds JWHracing builds a spare tire mount 3 JWHracing 8721 Re: JWHracing builds a...
 Tue Jun 16, 2009 06:49 PM
JWHracing View latest post
