Visitors: 93
Total: 93
06: Home
11: Home
20: Event Calendar
30: Home
48: Event Calendar
61: Event Calendar
63: Pictures
72: Event Calendar
79: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- anyone know how to install a windsheild on a bug?
madman74
madman74
Post Post subject: anyone know how to install a windsheild on a bug?
Posted: Sun Dec 10, 2006 07:20 PM
Hi, all I am trying to install the glass on my baja, but am having a tough time trying to get the gasket to stay on the windsheild. The gasket pops off the corners every chance it gets, and it wont stay on the bottom of the windsheild. Do you guys think it would be ok to use spots of super glue on the widsheild in places just to keep it on the glass? I got the 2 side windows in wih no problems.
Oops it broke!
Post Post subject: Re: anyone know how to install a windsheild on a bug?
Posted: Sun Dec 10, 2006 08:51 PM
Window install Link
www.azbaja.com/windshi...nstall.htm
This might help
fireman
fireman
Posted: Sun Dec 10, 2006 10:12 PM
Hey madman74 I live in east mesa if you need some help let me know I could swing by tomarrow and giv you a hand.
Rusty (602)206-0382
Rusty "fireman"
" With what we get, we can make a living; However with what we give, we can make a life"
Arthur Ash
madman74
madman74
Posted: Sun Dec 10, 2006 11:30 PM
I was using that link on how to install the windsheild, its very informative, the pitures help alot. If I can get the gasket to stay on the window I dont think I would have any problems getting it into the baja. I think maybe I just have a crapy gasket. Its acts as if its too big.
Thanks for the offer Rusty! I might need to take you up on that offer this thing is ticking me off! My hands hurt from trying to get this gasket on.
Thanks
Oops it broke!
bajasam96
bajasam96
Posted: Sun Dec 10, 2006 11:50 PM
I just put a new windshield into mine and had the same problems. I threw the new gasket away and went and bought a second new gasket and it went a little easier, also get it hot hot. I bought the "aloha breeze" from walmart for $10 and those two things combined allowed me to get the gasket to stay on. Ive never had that problem in the past, maybe a batch of gaskets went out that was a little shady.
VIN70
VIN70
Posted: Mon Dec 11, 2006 01:33 AM
mine wouldnt stay on the bottom either, the indshield is curved at the bottom i used some duct tape to hold it then cutit off when i got to that point. worked good
Posted: Mon Dec 11, 2006 02:56 AM
I have a cool glaziers suction cup that is a MAJOR help, especially in the bottom corners.
planenutz
planenutz
Posted: Mon Apr 28, 2008 01:05 AM
Window install Link
This might help
Perchance is there a new link to these?
Thanks Sad
Posted: Mon Apr 28, 2008 01:34 AM
www.azbaja.net/windshi...nstall.htm
planenutz
planenutz
Posted: Mon Apr 28, 2008 01:49 AM
http://www.azbaja.net/windshield_install.htm
Muchos Gracias Very Happy
Posted: Tue Apr 29, 2008 08:57 AM
Madman...
The windshield should take five minutes (maybe) and two people, once you get the gasket around the glass, which is the part you're struggling with. I've had fit problems before with gaskets. If it's loose, you WILL have problems. If it's too tight, it will probably work.
Here's the trick...
Get the gasket around the glass, SOAKING it in slippery hand soap (not the gritty kind) or dish soap and water.
I've never hear the kite string idea. I use ONE WRAP of 14 gauge electrical wire inside the channel of the gasket, overlaying it in the top middle.
Tuck the windshield in the lip of the opening at the bottom corners first, and have your buddy push HARD evenly while you bang on it (flat hands, not fists) as you get it to sink in closer to the windshield flange. Keep the hard pressure on!!!
You need two flat screwdrivers (#3 or #4). GENTLY pry the lip of the gasket over the middle top area where the wires overlap with one of the screwdrivers. Your buddy is still applying pressure, right? When you get the lip started, wrap both wires around the screwdriver shafts several times so pulling the wire doesn't kill your hands. Pull the wires, one at a time, and the lip of the gasket will schmooze over the lip in the body opening.
You're buddy is still applying pressure from the outside, right?
If you get stuck, just take one of the screwdrivers out of the wire and help the gasket through the opening again past the wire.
It helps if your buddy bangs his hand on the glass every once in a while to help it get smoother and deeper into the opening. Do both sides evenly until you get to the middle of the bottom. When the wire comes out (which it will once you pass all four corners) use a screwdriver again to finesse the rest of the lip at the bottom.
After you have the gasket lip sort of in all the way around... go outside (while your buddy is still applying pressure) and bang the crap out of it all the way around and it will drop right into place.
I'm guessing we could have done two or three of them in the time it took to type this post. They're a piece of cake as long as the gasket fits the glass.
If you think a windshield is challenging, try an oval rear window. They're a real SOB!
ajeden
ajeden
Posted: Wed Apr 30, 2008 05:40 AM
With reference to the last message. I find it easier to run a length of string around the rubber.
No new posts VW Volkswagen & Baja Bug General Discussion Engine Cage Install 12 1969Baja 13317 Re: Engine Cage Instal...
 Mon Sep 27, 2010 01:06 AM
No new posts VW Volkswagen & Baja Bug General Discussion where to find clutch slave install tips/instr.??? 6 bajabuggin 6225 where to find clutch s...
 Sat Sep 11, 2010 02:58 PM
az350x View latest post
No new posts VW Volkswagen & Baja Bug General Discussion HELP! i want to install an eco tec in my 64 bug 1 aswilson96 1855 Re: HELP! i want to in...
 Sun Oct 25, 2009 09:20 PM
No new posts Projects and Builds How To Install New Rear Suspension Bumper in 69?? 4 glenf 3013 How To Install New Rea...
 Wed Jun 17, 2009 03:54 AM
glenf View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Instructions to install 002 trans. in 1969 1600 Baja?J 12 glenf 11111 Re: Instructions to in...
 Fri Apr 24, 2009 06:45 PM
DONT View latest post
