Latest: ecthemc
Overall: 3567
Visitors: 142
Total: 142
03: Pictures
13: Garage
54: Event Calendar
56: Pictures
72: Event Calendar
97: Pictures
125: My Account
141: My Account
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- 71 baja build
71 baja build
OldSchoolBlake
OldSchoolBlake
Post Post subject: 71 baja build
Posted: Wed Jul 24, 2013 11:57 PM
Started off as a class 11 job, coil overs and 7.00-15 tires. Wanted to make it a bit taller and put some more tire under it, so I stared the Lifted Beetle project which is now a lifted baja project, due to all the rust and dent issues and it not being a pre-68.
So I put it up on jack stands and started pulling parts!
I didn't know at the time that you could just reindex the rear so I found a buggy that had a good reduction trans with a JJS no hop kit installed and transplanted.
That gave me 3.5 inches of lift in the rear, so I went with the tweeds 3.5 lift spindles in the front.
I liked the full body look but there is too much nasty on it for me, and it would be costly for me to have all the parts shipped to me so I guess it is baja time!
That's an awful lot of fender clearance on a 30" tire guess ill be going bigger, will see after I set the spring plates back down a bit.
In the process of replacing the floor pans, rear luggage area, quarter panels and fitting the fiberglass pieces.
Be good or be Good at it ;)
Last edited by OldSchoolBlake on Thu Jul 25, 2013 05:00 AM; edited 4 time in total
OldSchoolBlake
OldSchoolBlake
Posted: Thu Jul 25, 2013 12:00 AM
Hm.... Pictures aren't working out for me, how do you work that part of it?
Post Post subject: Re: 71 baja build
Posted: Thu Jul 25, 2013 02:14 AM
If your using photobucket move the mouse over the astrick in the upper right of the picture click get links then click the last choice whick copies it and paste it in your post
OldSchoolBlake
OldSchoolBlake
Posted: Thu Jul 25, 2013 02:55 AM
I was trying to upload them in the gallery and use like a forum link.
OldSchoolBlake
OldSchoolBlake
Posted: Thu Jul 25, 2013 05:04 AM
Thanks, I made a photobucket account and figured it out.
Posted: Thu Jul 25, 2013 01:56 PM
WOW Nice!
Posted: Fri Jul 26, 2013 06:11 PM
Wow. Lots of work. Cool
OldSchoolBlake
OldSchoolBlake
Posted: Sun Jul 28, 2013 02:03 AM
Almost time for paint.
4 Admin_AzBaja 5060 Baja Bugs on Wiki need...
1567 mufasavnvmc 838625 what did you do to you...
 Tue Aug 15, 2017 03:29 AM
285 MusicManiac 205800 Re: Baja sightings
Off-road event
1 wideopenmotorsports 125 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
26 1963BAJA 3629 The Socal Honda Build
 Fri Jun 23, 2017 12:15 AM
1963BAJA View latest post
