Visitors: 100
Total: 100
05: Home
37: Home
45: Home
61: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- VW TDI Engine swap?
VW TDI Engine swap?
Grunt-0341
Grunt-0341
Post Post subject: VW TDI Engine swap?
Posted: Fri Apr 19, 2013 07:58 AM
Can a VW TDI be put in a baja bug?
Grunt-0341
81mm Mortar Man
1st Battalion 6thMarines
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
Posted: Fri Apr 19, 2013 01:54 PM
Yes...
check with Kennedy for the adaptor kit...
661-272-1147
you need to call them.. there web site is not up to date.
Grunt-0341
Grunt-0341
Post Post subject: Re: VW TDI Engine swap?
Posted: Wed Apr 24, 2013 08:12 AM
Thanks Dalton. From what I gather it has been done before then. Any other tips? What about cost?
Grunt-0341
81mm Mortar Man
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
Posted: Wed Apr 24, 2013 06:10 PM
There's many right ways of making this conversion this is what I do with any project.
Before you spend any money sit down and write down what you want as an end result it's kind of like a blueprint draw it out if you have to. Go to car shows and take photos of what you would like to incorporate into your project and add them to your blueprint. This will save you from reengineering something. Then you work backwards on how much it's going to cost.
You got a consider a few things:
will I have the funds to complete the project correctly. Whatever you think it's going to cost it's usually double.
What am I willing to sacrifice so that I could afford to make this conversion. Remember to factor in your time. It usually takes three times as long as you plan for.
In this particular conversion you need to consider the additional weight that the water pumper wights
can might transmission handle the additional horsepower.
Can my CVs withstand the additional horsepower.
Do I have access to the proper tools for this conversion.
My yellow Baja was three years in the making before I even bought the donor car, but I was putting together a complete package from bumper to bumper. it took me nine-month's to locate the proper donor car.
After your blueprint is complete price things out when you have the additional funds purchase the items to make this conversion I would suggest getting that motor running outside the vehicle first I just find it easier to work on this way. I would not start a motor on in engine stand they tend to flip over the closer to the ground you get the less damage will occur if the motor gets loose. For some reason we always seem to feel the need to rev up a motor regardless if it securely mounted or not.
Posted: Wed Apr 24, 2013 08:42 PM
On top of that if it is late model computer controlled you will have to get the immobilizer written out of the program.
Grunt-0341
Grunt-0341
Posted: Wed Apr 24, 2013 10:17 PM
Thanks fellas. Are there any post here where someone has done it already?
Grunt-0341
81mm Mortar Man
1985 - 1989
Semper Fi
Rom 1:16
www.infowars.com
www.oathkeepers.org
thepatriots.us/
Posted: Thu Apr 25, 2013 12:57 PM
I dont know of anyone.
Posted: Thu Apr 25, 2013 03:23 PM
Try here:
forums.tdiclub.com/for...y.php?f=63
blg4351
blg4351
Posted: Thu May 02, 2013 01:06 PM
There was a pic of one in hot vw's from last years mannassas va bug out. Purple huge monster of a Baja with a diesel in it. You may be able to search it and see if it comes up.
No new posts Projects and Builds Toyota 3tc swap
Baja bug toyota swap
14 Sandrailbuilder 9374 Re: Toyota 3tc swap
 Wed Apr 18, 2018 10:21 PM
No new posts VW Volkswagen & Baja Bug General Discussion Engine kit 0 andrewbaja 1244 Engine kit
 Thu Mar 29, 2018 04:13 AM
andrewbaja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Engine Work 5 ghs215 2010 Re: Engine Work
 Mon Jan 08, 2018 12:59 AM
No new posts VW Volkswagen & Baja Bug General Discussion VW engine stand 2 ghs215 2344 Re: VW engine stand
 Thu Jun 01, 2017 10:28 PM
Trevabooooy View latest post
6 AZOffroadSwapmeet 3840 AZ Off-Road Swap Meet
 Fri Dec 09, 2016 02:37 PM
