Latest: BlackIrish05009
Overall: 3574
Visitors: 120
Total: 120
44: Event Calendar
53: Pictures
55: Event Calendar
My 69 project
1 2 3 ... 76 77 78 79
Azdrtdog
Azdrtdog
Posted: Wed May 24, 2017 05:58 PM
Time to put coilovers on dalton
Posted: Fri May 26, 2017 01:53 PM
ordered my 29mm got my standard adjustors. looking at the car.... Dam ... this is going to be a lot of work.
Azdrtdog
Azdrtdog
Posted: Fri May 26, 2017 01:57 PM
Lot more work then coils and you still have to worry about it breaking again
Posted: Tue Jun 06, 2017 01:27 PM
Got the 29mm torsion Friday.... I called and the splined center is on back order... Unknown ship date...
Bummer.
Posted: Tue Jun 13, 2017 02:22 AM
got the motor out... not too bad.. made a few changes to my oil lines... found only 2 bolts loose!!!! WOW!!! I was able to pull the motor with out opening up the AC system ... worked like a charm...
stopped just short of opening up the CV's ... going to start on them Tuesday... did some searching on the internet and found out how to get 32degrees out of them.??.. I will check it out when I go to put them back in.
found out why my throttle cable was sticking... I did not see that coming. but the housing was getting pulled back ... got to get that fixed ..
Azdrtdog
Azdrtdog
Posted: Tue Jun 13, 2017 03:22 AM
will torsion bars like 32 degrees is the next ?
Azdrtdog
Azdrtdog
Posted: Tue Jun 13, 2017 07:51 PM
maybe a nice quarter elliptical spring setup, that would be unique
Posted: Wed Jun 14, 2017 12:08 AM
32 degrees on my 930 CV's
Azdrtdog
Azdrtdog
Posted: Wed Jun 14, 2017 12:14 AM
yes I know, my thoughts were with the torsion bars cycling 24" of travel so you could benefit from cv's that have that much angle
Posted: Wed Jun 14, 2017 01:32 PM
I was told that torsions bars can twist up to 2.5 turns before breaking.
Azdrtdog
Azdrtdog
Posted: Wed Jun 14, 2017 01:44 PM
I totally want to test that claim
Posted: Mon Jun 19, 2017 01:38 PM
UGH.... well I have the trans pulled and every thing out of the way...
Guess what.... I blew the outer splines... All that work.. and I blew a spring plate. I could have been back up and running in a few hours ...
oh well... been doing some small changes here and there.
last night I decided I am going to replace the inner splines anyway ... they are a weak spot ...
I am ordering up some parts today..
Posted: Fri Jun 23, 2017 02:17 PM
Posted: Fri Jun 23, 2017 02:19 PM
I am ready.... where is my replacement splines???
Posted: Fri Jun 23, 2017 02:22 PM
now you can get a better look at the way I did my heater and other lines..
No new posts Projects and Builds Project Purple People Eater 3 Yasha7fold 1756 Project Purple People ...
 Wed Jul 12, 2017 08:03 PM
Yasha7fold View latest post
88 Dirtjunkie 55019 Project II
65 PaDan 51526 Re: My project
 Thu Feb 11, 2016 07:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 7203 Re: new project
38 NoKnowledgeCollegKid 18482 Thinking about a Baja ...
 Wed Apr 01, 2015 12:01 PM
