Visitors: 228
Total: 228
09: Pictures
13: Event Calendar
26: Pictures
49: Home
50: Home
62: Event Calendar
76: Event Calendar
87: Event Calendar
107: Pictures
108: Pictures
123: Pictures
139: Event Calendar
150: Baja Forums
154: Baja Forums
155: Event Calendar
162: Pictures
164: Baja Forums
166: Event Calendar
178: Baja Forums
180: Pictures
182: Home
183: Baja Forums
184: Baja Forums
186: Event Calendar
187: Baja Forums
189: Baja Forums
190: Event Calendar
193: Home
194: Baja Forums
195: Baja Forums
196: Baja Forums
197: AMAZON.com
198: Baja Forums
201: Baja Forums
202: Event Calendar
204: AMAZON.com
205: Event Calendar
207: AMAZON.com
208: AMAZON.com
209: AMAZON.com
210: Baja Forums
212: AMAZON.com
213: Baja Forums
214: AMAZON.com
215: Baja Forums
217: Pictures
218: Baja Forums
219: AMAZON.com
220: AMAZON.com
221: AMAZON.com
225: Pictures
226: AMAZON.com
227: AMAZON.com
My 69 project
1 2 3 ... 7 8 9 ... 78 79 80
Posted: Wed Jun 19, 2013 01:51 AM
Then late that die down lining it up with your drawing
Posted: Wed Jun 19, 2013 01:53 AM
The first band doesn't matter it only needs to be a 90
then mark on the ground where the die begins.. And then work your way around the project marking each bend where the die begins.
Posted: Wed Jun 19, 2013 01:55 AM
If you really need to be precise you will need the lock the two in place to keep it from being pulled through the Bender as you bend a simple clamp will do the trick.
Continue to mark each bend in the direction that you will be bending it until you complete each mark.
Posted: Wed Jun 19, 2013 01:57 AM
Posted: Wed Jun 19, 2013 01:59 AM
After each bend lathe the project back down on the drawing and mark where the die begins on the tubing so that you can line it up while it's in the Bender.
Posted: Wed Jun 19, 2013 02:01 AM
Repeat until done.
Posted: Wed Jun 19, 2013 02:06 AM
Cut the tube halfway
Posted: Wed Jun 19, 2013 02:07 AM
Done..
Posted: Wed Jun 19, 2013 02:14 AM
sorry
Done.
pepeazul
pepeazul
Posted: Wed Jun 19, 2013 04:22 AM
Slick and straightforward.
The guy I worked for back in high school used this technique. I adopted a center-out method later on and still use that because it just makes more sense to me and I prefer to do the layout in my head... You know what they say, measure once, cut twice Confused
pepeazul
pepeazul
Posted: Wed Jun 19, 2013 04:26 AM
BTW, I like the work boots! Are those OSHIT approved?
pepeazul
pepeazul
Posted: Wed Jun 19, 2013 04:31 AM
Dalton, You'll appreciate this.
www.pirate4x4.com/foru...ender.html
Posted: Wed Jun 19, 2013 06:37 AM
Wow, great info!
I like that homemade bender!
Posted: Thu Jun 20, 2013 01:46 AM
This is not a homemade Bender it is a very old hossfield Bender. It has been extensively modified so that it will make a bend over 180°.... On that note anything over 180° I have to pound off the die... The hydraulics were added the way that they are is because the previous owner did not like the way Hossfield hydraulics worked.
Posted: Thu Jun 20, 2013 01:48 AM
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 3361 Project Purple People ...
88 Dirtjunkie 62594 Project II
65 PaDan 56970 Re: My project
 Thu Feb 11, 2016 06:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 8316 Re: new project
38 NoKnowledgeCollegKid 21704 Thinking about a Baja ...
 Wed Apr 01, 2015 12:01 PM
