Latest: hulkbaja
Overall: 3594
Visitors: 101
Total: 101
04: Home
20: Pictures
23: Event Calendar
25: Links
40: Event Calendar
51: Event Calendar
54: Event Calendar
55: Event Calendar
57: Links
67: Home
82: Pictures
93: Home
96: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- lifted spindles and disc brake update
vwboat
vwboat
Post Post subject: lifted spindles and disc brake update
Posted: Sun Mar 10, 2013 03:18 PM
Thanks to Karls VW (John and Chris) I now have a new set of Kustom1 lifted spindles and disc brake kit to install on my car. Hope to be done for the run this weekend to Sundad. So far this kit looks really good, better than the orignal EMPI kit I had to return due to bad spindles. Hope the install goes well and my car is back down on the floor soon..Hope to see you in the dirt this weekend.
VWBOAT(john)
vwboat
vwboat
Post Post subject: Re: lifted spindles and disc brake update
Posted: Sun Mar 10, 2013 10:49 PM
First problem with the new disc brake install. The lifted spindle install went OK. Installed the disc rotors OK, installed the new calipers and that went OK. My problem is that my wheels now hit the caliper when I mout them to the hub.
Do I need new wheels with different backspacing for the disc brake set up?
I have white spokes that seem to be standard wheels.
VWBOAT (john)
Posted: Sun Mar 10, 2013 11:19 PM
I had to grind my calipers down to get them to clear.. it seems to be a standard ... I have had to grind a them on a few cars I have owned... fround and rear.
Posted: Sun Mar 10, 2013 11:38 PM
Posted: Sun Mar 10, 2013 11:39 PM
I get them close and then drive around and let my "stud heads" finish the job.
or you can run a stock wheel.
Posted: Sun Mar 10, 2013 11:55 PM
I had to grind mine on a previous bug too.
vwboat
vwboat
Thanks for the reply Dalton. It looks like I will have to do the same to run my white spokes. Looking at your pictures it looks like that there is enough material on that side of the caliper to grind ok. It also looks like you have some spacers on your lug bolts, am I seeing that right?
Thanks again. VWBOAT(JOHN)
Posted: Mon Mar 11, 2013 03:01 AM
yes... I am useing some washers.. it is very "cheesey" but it worked ... I need to redo the whole thing with the spacers on my spindles. I just have not gotten back to it yet.
Posted: Tue Mar 12, 2013 04:30 PM
Karls used to stock 1/4 " aluminium spacers. I used them to make up for the extra long splines on Sway Away 14 mm studs.
vwboat
vwboat
Posted: Tue Mar 12, 2013 05:54 PM
tHANKS FOR THE TIPON THE SPACERS PERRIB. i WILL CHECK THEM OUT.
joHN
Posted: Fri Mar 15, 2013 05:01 AM
I use a 3/8 Aluminum spacer (could be a 1/4). I use Studs from a full size truck. The car is at Perrys place he can always take some photos to show how it is set up. If you use stock VW wheels your ok. The rims we use on off road cars are the problem.
vwboat
vwboat
Posted: Fri Mar 15, 2013 03:12 PM
Thanks to all for the info and replys. I have ground down the calipers and the rims fit OK. Still would like to put in wheel studs and spacers for a little more clearance. All seems to be OK now. Car is now back on the ground and just need to adjust rears and bleed all 4. Was trying to make the ghosttown run on Sat but don't think I am going to be done in time due to other commitments.
John(VWBOAT)
vwboat
vwboat
Posted: Fri Mar 15, 2013 11:00 PM
Still trying to get new wheel studs or lugbolts that will allow me to use the wheel spacers I want to use on my BAJA. Big PAIN trying to source stuff to fix this effort, no one in town seems to have what I need. About ready to just yank this crap off my car and go back to drum brakes.....
John
Posted: Sat Mar 16, 2013 12:48 AM
get the studs/nuts from AZtrans .. if you need them this weekend go to BAP get the ones that you need to press in...NOT the ones that you screw in. they are un safe!!! if you need them pressed in I can do it for you Sunday.. Please dont try to install the studs with the disks still on the car... if you need to get down the road for now just use stock rims.
Posted: Sat Mar 16, 2013 03:05 AM
1 LittleBaja 2379 Re: Brake Drum 4 to 5
 Sat Oct 03, 2015 04:52 AM
3 LittleBaja 2231 Re: Brake Drum 4 to 5
 Tue Sep 29, 2015 06:08 PM
No new posts VW Volkswagen & Baja Bug General Discussion Brake light switch?? 3 sandbuggy 3221 Re: Brake light switch...
 Sun Nov 17, 2013 08:21 PM
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 3523 Re: bj front disk brak...
 Thu Dec 13, 2012 03:03 PM
what are yall's set'ups
7 vindeta 14483 Re: lights?????? (hea...
 Tue Oct 11, 2011 05:32 AM
