Latest: jor_dang420
Overall: 3597
Visitors: 73
Total: 73
08: Event Calendar
10: My Account
13: Pictures
16: Event Calendar
19: Event Calendar
27: Event Calendar
45: Event Calendar
59: Home
73: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- sticking accelerator cable
65bajabug
65bajabug
Post Post subject: sticking accelerator cable
Posted: Sat Sep 04, 2010 02:46 AM
hey everyone i have 1965 Baja and when i drive it my accelerator cable and i'm worried about this because its a safety issue, any advice would be helpful. Thanks
"My car isn't a piece of shit it's custom"
Post Post subject: Re: sticking accelerator cable
Posted: Sat Sep 04, 2010 04:09 AM
You mean it is no fun turning off the ignition? Is it missing a carb spring? Disconnect the cable and start it up work the carb to see if it is the carb hanging up. Some times the cable frays in the tube or the tube is full of dirt. Also look at the acc. pedal for binding there.
chickenpants
chickenpants
Posted: Sat Sep 04, 2010 03:30 PM
Mine was very difficult to press but not sticking. It broke and I had to replace it on the side of the road. The first thing I noticed was that it was easy and very smooth. You may have some fraying of the cable. Takes just a sec to replace it.
Stephen\r\nChandler, Az
65bajabug
65bajabug
Posted: Mon Sep 06, 2010 03:57 AM
I dont have to turn of the ignition to stop it from sticking i have a roller pedal installed so i am able to pull it back. Im worried about if it sticks and im not paying attention and i hit someone.
Posted: Mon Sep 06, 2010 05:29 AM
Definitely better find the problem and fix it. Maybe disconnect it at the carburetor, and (with a helper) work the pedal back and forth while holding the cable end to try and determine if it's in the cable or not. If not, must be carb linkage. You're asking for trouble if you keep driving it like that!
Posted: Mon Sep 06, 2010 05:02 PM
Did you check what I suggested you check?
chickenpants
chickenpants
Posted: Mon Sep 06, 2010 06:37 PM
Hope you don't run over someone's kid
jone$yyy
jone$yyy
Posted: Tue Sep 07, 2010 06:03 AM
just connect a piece of rope to the carb and pull it.
always a good way to get home if it breaks
but i would check for the spring on the carb and just pull the old one out and put a new one in with a bunch o' grease in it
and i highly doubt it will stick
Posted: Tue Sep 07, 2010 06:06 AM
Huh? You lost me with the rope on the carb, Jethro. Laughing
Grease the carb spring?
65bajabug
65bajabug
Posted: Tue Sep 07, 2010 06:33 PM
I will try and look at it this weekend if i have the time. Thanks everyone
Mandocan22
Mandocan22
Posted: Wed Sep 08, 2010 01:42 AM
i have a Sand rail and mine was sticking from the cable or shall i say the locking tab or barrel that holds the cable it was hitting the carb when i pushed down on the accelerator then holding at full idle having to turn it off it was working itself loose at first. but after a few times i figured it out. put some elec tape around it so it wouldn't slide from slide to side. hope this helps. new at this rail and vw engine so not very tec'y on part names.
nshoe18
nshoe18
Posted: Wed Mar 13, 2013 12:29 AM
We just got a 1970 bug that had been rebuilt. The accelerator is a roller pedal and connected to the same base rod that the brake and clutch are on. The accelerator pedal seems to stick when you press or hold the clutch. While pushing the pedal with your hands you can see the rod spinning and all the nuts spin at the same time and the accelerator stays down until you release the clutch pedal. Do the nuts all need to be loose or should we rerun the pedals to have the clutch and brake together and the accelerator as a standalone pedal?
No new posts VW Volkswagen & Baja Bug General Discussion Throttle cable shenanigans... 4 fast_1 2728 Re: Throttle cable she...
 Wed Apr 22, 2009 02:23 AM
fast_1 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion brake pedal is sticking... 8 danjones333 2657 brake pedal is stickin...
 Fri Feb 20, 2009 07:01 AM
danjones333 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion throttle cable.
20 shpuz 4691 Re: throttle cable.
 Tue Jan 22, 2008 01:11 PM
kcnaz View latest post
No new posts VW Volkswagen & Baja Bug General Discussion oy... throttle cable! 13 shpuz 7198 Re: oy... throttle cab...
 Fri Dec 28, 2007 03:47 PM
No new posts VW Volkswagen & Baja Bug General Discussion speedometer cable instal 6 todd 3242 Re: speedometer cable ...
 Sun Aug 12, 2007 05:46 PM
todd View latest post
