Latest: Smokey4
Overall: 3593
Visitors: 118
Total: 118
14: Home
21: My Account
40: Home
44: Pictures
82: Event Calendar
106: Home
112: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- help se le agradese
help se le agradese
Veneco
Veneco
Post Post subject: help se le agradese
Posted: Mon Feb 18, 2013 11:53 PM
Someone will have a photo to get an idea as it looks or how wide my stay low with these arms? They have 1/2 inch longer
www.cbperformance.com/...tCode=4502
M J S R
Post Post subject: Re: help se le agradese
Posted: Sun Mar 03, 2013 10:02 PM
You won't see less body lift due to leverage. The longer bars will compress the torsion leaves more. The 1.5 longer arm will require modifying the fender at the body side as you have just shortened your wheel base by 1.5 ". With fenders you will notice the 1/2 inch wider arms, in a rail you may not notice it at all. You will get a much better ride with them and correctly valved shocks. You could cut and turn one beam center clamp to raise it back a bit.
