Visitors: 108
Total: 108
16: Garage
81: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- My Build
My Build
Zjvdwerf12
Zjvdwerf12
Post Post subject: My Build
Posted: Tue Jan 01, 2013 12:32 AM
This is the concept for my baja, it will probably be another 5-6 months before I can actually get started on the build. Hoping to run 33x10.5" tires, 1600 engine or possible bore to 1900ish, planning on 20" suspension travel with 930 cv's and 3x3 trailing arms. Don't know about transmission yet. The volkswagen on the windshield will also be filled in white. What are your guys' thoughts or suggestions?
Here is the link to a folder with more pictures.
docs.google.com/folder...dKS28/edit
Posted: Tue Jan 01, 2013 01:44 AM
welcome to the site. Looks like you have some good ideas
LT_Spenny
LT_Spenny
Posted: Thu Jan 03, 2013 05:12 AM
i like the hood!
Build: "Lucky 13"
LT_Spenny
LT_Spenny
i like the hood!
Build: "Lucky 13"
Posted: Thu Jan 03, 2013 06:15 AM
20" front travel is a tall order. With coilovers and 4" over front arms, you can get maybe 17". 33x 10.50s are mighty big on the front.
Where do you plan to use this Bug?
Zjvdwerf12
Zjvdwerf12
Posted: Sun Jan 13, 2013 02:07 AM
Right now I will be using it on wooded, wet, and muddy trails in Tennessee. Eventually (2+ years) I will be ending up back in the valley, at which point I will set it up to run around in the desert.
26 1963BAJA 7371 The Socal Honda Build
 Fri Jun 23, 2017 12:15 AM
1963BAJA View latest post
Cheapskate special
26 Azdrtdog 11432 New father/son budget ...
 Fri Jun 16, 2017 10:26 PM
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 5240 New Class 11 Build - P...
101 SuburbanLegend 134688 Carbon Footprint...aka...
 Thu Oct 08, 2015 08:28 PM
61 1450bug 52866 1450Bug Build
 Fri Jan 23, 2015 02:41 AM
