Latest: BlackIrish05009
Overall: 3574
Visitors: 123
Total: 123
02: Pictures
41: My Account
72: Event Calendar
110: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Clutch Issues
Clutch Issues
Pointvirus
Pointvirus
Post Post subject: Clutch Issues
Posted: Sun Dec 02, 2012 06:00 PM
So we pulled out the transmission in my bros 64 baja bug. We swapped tranny's to find that that didn't fix the problem.
The car wont shift into gear.
The clutch cable isn't stretched.
The clutch pedal moves with the trans lever.
We drilled three holes in the tunnel to check the clutch cable tube which is still intact.
The pressure plate is almost brand new (says the shop)
I think it could be the throw out bearing but us nor the shop know what the problem is.
any ideas?
Posted: Sun Dec 02, 2012 06:03 PM
Shift Coupler, or your throw out bearing is the wrong type for the pressure plate that you're using.
How does the pedal feel? When does it feel as though it engages with the clutch? At the bottom of the pedal travel or top?
Pointvirus
Pointvirus
Posted: Mon Dec 03, 2012 04:58 AM
The pedal travel is set perfect and the throw out bearing was the original from the previous trans. The only other thing the shop could think of was the fork that the bearing sits on. We talked to them today and they said that it might need to be replaced.
I don't get the whole setup yet but I know that the lever on the trans is real free moving. it doesn't take much for it to pull and so I think that it's not engaging the clutch. Also... I can switch into any gear with out using the clutch pedal. It shift's almost perfect. I don't have any gas in the car so I haven't got to really drive or attempt to. Starts up fine though.
Post Post subject: Re: Clutch Issues
Posted: Mon Dec 03, 2012 05:38 AM
Different year transaxles require different pressure plates.
Non trans cause stripped hub.
Your post lacks data. For me there is no detail of what the symptom was befre you swapped the transaxle.
Posted: Mon Dec 03, 2012 07:33 PM
If the lever is Freely moving without resistance then it isn't engaging with the Pressure plate. If the pedal pushes all the way to the floor and you don't feel resistance, it's not engaging either.
I had one side of the throw out bearing fall off once when I didn't adjust the preload correctly. It always seems the keeper pins suck.
Sounds like it's not engaging and unless it's running, it will shift into gears fine. If it shifts into gear while running and doesn't go anywhere that's a whole different issue.
Put it into gear and give it a push while it's not running. Does the engine turn?
2180 Baja bug with 091 trans.
11 51BUG50 3129 Clutch and pressure pl...
 Fri Mar 10, 2017 08:22 PM
No new posts New Members Air filter issues
Can't keep the Dust out
11 DerekT 4056 Re: Air filter issues
 Mon Oct 03, 2016 01:59 PM
No new posts VW Volkswagen & Baja Bug General Discussion Motor issues 12 Dirtjunkie 3727 Re: Motor issues
 Mon Sep 19, 2016 09:06 PM
parts
0 bajablastman1214 1785 Clutch
 Sun Aug 16, 2015 05:23 AM
No new posts VW Volkswagen & Baja Bug General Discussion where to find clutch slave install tips/instr.??? 6 bajabuggin 5432 where to find clutch s...
 Sat Sep 11, 2010 02:58 PM
az350x View latest post
