Visitors: 114
Total: 114
01: Home
02: Home
13: Home
21: Event Calendar
43: Pictures
80: Event Calendar
89: Home
90: Home
111: Garage
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- quick help/won't start
Pointvirus
Pointvirus
Post Post subject: quick help/won't start
Posted: Sat Jul 28, 2012 08:33 AM
The baja wont start.
The key's blow the ignition fuse
when I go direct on the starter it spins but wont engage.
the other night it started right away but then died and nothing would start.
the power on the radio flashed dimly every time I tried the ignition. Nothing else.
classicveedub
classicveedub
Posted: Thu Oct 18, 2012 11:36 PM
check the fuel line
Regards,\r\nMohammed
Posted: Fri Oct 19, 2012 09:42 AM
Check the smaller wire coming off the positive side of the battery to make sure it's still connected. If it brakes loose it kills the ignition. Blowing fuses isn't good and maybe something is pinched? You could also have a bad ground strap or connection.
Post Post subject: Re: quick help/won't start
Posted: Fri Oct 19, 2012 11:21 AM
If the fuse is blowing you need to find the wire on that circuit that is shorted to ground.
Pointvirus
Pointvirus
Posted: Sun Oct 21, 2012 07:42 AM
oddly enough it just needed a new alternator.
The generator and the sub/amp setup just wasn't working.
and the starter had a gear out.
No new posts Projects and Builds Just a quick little project...
56 wideopenmotorsports 51152 Just a quick little pr...
 Sat Mar 07, 2015 11:29 PM
yellowchev View latest post
No new posts Club AzBaja (Arizona Chapter) electrcial quick connections for winch. (DALTON) 7 vwboat 2788 electrcial quick conne...
 Sun Apr 20, 2014 02:42 PM
No new posts VW Volkswagen & Baja Bug General Discussion hard start relay 4 vwboat 2185 hard start relay
 Wed Oct 17, 2012 10:18 PM
Pointvirus View latest post
No new posts VW Volkswagen & Baja Bug General Discussion quick easy increase in HP? 5 woodin 3506 Re: quick easy increas...
 Wed Sep 07, 2011 11:36 PM
Ejbbal21 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Start of a new baja 3 Shorty 3018 Re: Start of a new baj...
 Mon Jul 18, 2011 04:14 PM
