Latest: rcwtony
Overall: 3607
Visitors: 127
Total: 127
21: Pictures
111: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- another rear axle question
onthefarm
onthefarm
Post Post subject: another rear axle question
Posted: Sat Aug 04, 2012 04:59 AM
Do the 4 bolts around the axle have to come off to remove the outer bearing?
Posted: Sat Aug 04, 2012 05:08 AM
yes. there should actually be a seal in that 4-bolt cap
onthefarm
onthefarm
Posted: Sat Aug 04, 2012 05:10 AM
Ok, the seal is out.
The only thing that is left is the roller bearing outer race.
onthefarm
onthefarm
Posted: Sat Aug 04, 2012 05:22 AM
Ok, thanks!!
I guess I will stop beating on it!!
You have been a BIG helpnto me!!!
16 DerekT 6266 Axle's needed
 Sat Dec 10, 2016 06:17 PM
No new posts VW Volkswagen & Baja Bug General Discussion Max angle for rear axles 5 Wattsd 4964 Re: Max angle for rear...
 Fri Jan 29, 2016 04:03 AM
Wattsd View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Rear Rim Backspacing 1 LittleBaja 2997 Rear Rim Backspacing
 Fri Nov 06, 2015 03:13 AM
JWHracing View latest post
No new posts Projects and Builds Swing Axle Dual Shocks 2 dave46 5256 Re: Swing Axle Dual Sh...
 Fri Sep 11, 2015 08:06 PM
dave46 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Baja Bug Modification question 4 Ailill 9916 Baja Bug Modification ...
 Mon Apr 13, 2015 04:07 AM
Ailill View latest post
