Latest: rcwtony
Overall: 3607
Visitors: 132
Total: 132
07: Pictures
10: My Account
53: Home
55: Contact Admin
72: My Account
90: Home
92: Memberships
93: My Account
94: My Account
95: Event Calendar
107: Contact Admin
112: My Account
113: My Account
114: My Account
116: My Account
121: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Number on the shock tower
onthefarm
onthefarm
Post Post subject: Number on the shock tower
Posted: Wed Jul 25, 2012 04:41 AM
I have a Baja with the VIN under the back seat says it is a 66. It has an IRS on it, It is not stock. so can anyone tell me what the number on drivers side rear shock tower of an IRS rear end
means if anything?
This is the number on the shock tower
I was told the brake drums are too big for a standard bug but it might be from a bus?
I need a new axle but not sure what to oredr.
Any help would be great!
onthefarm
onthefarm
Posted: Wed Jul 25, 2012 05:01 AM
this is another view of the rear end.
if other pics would help let me know.
Posted: Wed Jul 25, 2012 06:03 AM
Looks to me like a 66 pan with an IRS conversion. Some pictures of the pivot clips might help.
onthefarm
onthefarm
Posted: Wed Jul 25, 2012 06:20 AM
Sorry im a noob.
Not to sound stupid but would that be the trailing arm pivot point?
Posted: Wed Jul 25, 2012 06:26 AM
yepp. that's the one. every 69 and up car (IRS from the factory) that i've ever seen, there are no holes in the upper shock mount like the pictures you've shown. Someone else correct me if i'm wrong but that's how everyone looks that i've ever seen.
onthefarm
onthefarm
Posted: Wed Jul 25, 2012 06:53 AM
Ok I will get a better pic of it tomorrow.
if you look in the pic I am trying to get the rear axle out, the spacer between the bearings is stuck to the axle. If I need a new one, one from a 66 wont work because this is an IRS and in 66 they were swing axles. Right?
Posted: Wed Jul 25, 2012 07:03 AM
correct. 69 and up, IRS.
the piece you are trying to get out is actually the "stub axle". it actually has a bit of a press fit, so some slight "love" with a hammer may be necessary. i'd use a piece of wood or something so you don't mushroom or ruin the threads on the stub axle. there is actually a puller made for doing this, but the hammer method has always worked just fine for me.
onthefarm
onthefarm
Posted: Wed Jul 25, 2012 07:26 AM
Ya I'm way past the "little love " part.
If I had a torch I would be on the road today!!
I split a lot of 2x4's trying not to bugger the threads. So I put the nut on it and beat the living tar out of it! Ya I know it was wrong to do but Dang!
The nut mushroomed to the point the 1 7/16 socket wont fit anymore.
live and learn.
I will get more pics.
onthefarm
onthefarm
Post Post subject: Re: Number on the shock tower
Posted: Thu Jul 26, 2012 02:38 AM
Ok, this is the pivot clip/mount.
Unless my grandfathers uncle was a crappy welder this was replaced (back in the day I had a few relatives that worked in the VW factory).
This is the whole drivers side.
I was told the brake drums were maybe from a bus?
I need to replace the bearings and brake shoes but I don’t know what to get.
Anything that is 69 and newer?
thanks
Posted: Thu Jul 26, 2012 02:52 AM
the pivot wasn't actually replaced, it was added in. So your 66 pan that originally was a swing axle has been converted to late model IRS.
i'm not positive on the brakes but they could actually be Type 3 brakes which are bigger than Type 1. Look up the part number on the wheel cylinder and compare it to what it might be.
Posted: Thu Jul 26, 2012 03:07 AM
- Pan is 1966.
- The 111 ... number on the tower is the part number of the tower forging. And YES, They are forged. many people call them castings, but they are definitely forged. They can be welded on, no issues, MIG, Flux Core, Stick Arc, etc.
- The IRS pivot brackets are aftermarket, not VW. they were welded on by some individual in the 1980s or later.
- The brakes appear to be VW Type 3. If the drums are 5-lug, the brakes are 1967 or earlier T3. Get brake parts for a T3.
- The stub axles appear to be stock Type 1, 1969 or newer.
- The nut needed to have come off the axle before you pounded the nut permanently onto the axle It will only get tougher now. Shocked You may have to knock it back towards the outside and cut the end off inboard of the nut.
onthefarm
onthefarm
Posted: Thu Jul 26, 2012 05:46 AM
WOW!
I knew i should have come here first, yall gave me more info in such a short time than anyplace else.
MojaveRacer208 - the drums are 4 lug.
i did get the nut off with a drill and a good cold chistle.
JWHracing - "Look up the part number on the wheel cylinder "
im not sure of the location of this number.
is it stammped some place?
Posted: Thu Jul 26, 2012 06:09 AM
Yup
There is a number cast in the upper side of the wheel cylinder shown here. It would have matched the original parts list, but may not match modern lists 45 years later. They may have been replaced somewhere along the line. I would expect the number to start with "311". Two factors important in swapping VW wheel cylinders around is the working length from the bottom of the saddle for the shoe on one end of the cylinder to the same point on the other end, and the offset dimension from the centerline of the cylinder to the face of the shoulder for the backing plate.
And there is a spreader bar for the parking brake and the return spring which goes with it missing in this brake assembly. The "nails" for the shoe retainer springs are bent, maybe from the other pieces not being there.
So did you get the axle out?
onthefarm wrote:
thanks
Welcome!
Posted: Fri Jul 27, 2012 10:26 PM
Another tip if your going to bang the tar out of somthing like this flip the nut around so you bang on the flat and do not turn the all the way down so you do not smash up your stub axle.
The castle of the nut shater and chunks could fly. so hope you have somthing on over your eyes.
onthefarm
onthefarm
Posted: Sat Jul 28, 2012 01:37 AM
Damn! Turn the nut around!
That is GENIUS!!!
Well I finaly got the axle out. The inner race of the outer bearing galled on the shaft.
Took it to work put it on the lathe cleaned up the galled spots and fixed the threads and now its good to go.
I just want to say THANKS guys for all yalls help and information!!
PRICELESS!!!
No new posts VW Volkswagen & Baja Bug General Discussion Shock Hoops
Wanting to build shock mounts without cutting the body
29 POCman 27480 Re: Shock Hoops
 Thu Nov 15, 2012 07:50 AM
POCman View latest post
No new posts VW Volkswagen & Baja Bug General Discussion shock setup 5 thext94 5395 Re: shock setup
 Wed Apr 14, 2010 02:16 PM
No new posts VW Volkswagen & Baja Bug General Discussion I need a rear shock 0 perrib 1741 I need a rear shock
 Sat Jul 18, 2009 05:44 AM
No new posts VW Volkswagen & Baja Bug General Discussion Shock Towers new picks!
30 DRUMMOND 41572 Re: Shock Towers new p...
 Tue Sep 23, 2008 11:05 AM
No new posts VW Volkswagen & Baja Bug General Discussion Wet Suit Shock Barriers 3 57baja 3246 Re: Wet Suit Shock Bar...
 Wed Jun 18, 2008 07:21 AM
WaBaja View latest post
