Visitors: 117
Total: 117
66: Pictures
85: Event Calendar
91: Event Calendar
108: Event Calendar
111: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- What would you buy?
What would you buy?
72BajaBen
72BajaBen
Post Post subject: What would you buy?
Posted: Thu Nov 23, 2006 06:54 AM
If you had 2000$ to spend and your car was running good. What would you buy?
72BajaBen
72BajaBen
Post Post subject: Re: What would you buy?
Posted: Thu Nov 23, 2006 07:13 AM
BTW this isnt a wish list. im looking for input on what would be the best way to spend the money that i have. the best upgrades and such.
6Rage
6Rage
I, personally because i niether have the money or the bug, would buy another one
My other cars a UDLX
Need to know the method to my madness? email me I'll tell ya bajarage @ hotmail.com.
72BajaBen
72BajaBen
Posted: Thu Nov 23, 2006 07:36 AM
naa i dont want another car. i want to upgrade this one.
6Rage
6Rage
Posted: Thu Nov 23, 2006 08:17 AM
WHat is the weakest point on your car?
WHat dont you like about yours?
Posted: Thu Nov 23, 2006 04:36 PM
I would build a big motor. At least a 1915 and put in a bus IRS.
madman74
madman74
Posted: Thu Nov 23, 2006 05:15 PM
A roll cage is always a good thing to have.
Oops it broke!
Posted: Thu Nov 23, 2006 05:24 PM
AirConditioning
VWDavo
VWDavo
Posted: Thu Nov 23, 2006 06:26 PM
Moe Betta Suspension!
-Gerald Ford
VWDavo
VWDavo
Posted: Thu Nov 23, 2006 06:33 PM
and disk brakes
-Gerald Ford
72BajaBen
72BajaBen
Posted: Thu Nov 23, 2006 07:01 PM
so what kind of axles do i have to use to use a bus tranny? do i need to change over to 930 cv's when using stock trailing arms?
Posted: Thu Nov 23, 2006 07:54 PM
SAW sells the conversion axles, they are 15 5/8 " and you dont have to go to 930's www.swayaway.com/VW%20frameset.htm
saltyslug
saltyslug
Posted: Thu Nov 23, 2006 08:47 PM
3x3 bro, you will never be upset about that purchase. disk breaks is good too. start in the rear and work your way foward.
72BajaBen
72BajaBen
Posted: Fri Nov 24, 2006 07:18 AM
if i do go with the 3x3 trailing arms do i need to convert over to coil over or can i still use my stock shock mounts?
72BajaBen
72BajaBen
Posted: Fri Nov 24, 2006 07:43 AM
would it be better to buy a kit, like the Beanie Boy Kit ($1100), or piece together my own for 3x3 trailing arms?
