Latest: thelataviayoung
Overall: 3584
Visitors: 122
Total: 122
01: My Account
16: Pictures
25: My Account
85: Pictures
89: Event Calendar
90: Pictures
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Little red baja build (picture heavy)
blubaron66
blubaron66
Post Post subject: Little red baja build (picture heavy)
Posted: Tue Jun 26, 2012 04:44 AM
Started my baja build and wanted to share some pics.
I hope you enjoy watching my build this summer...
started with your basic fender removal...
then made my cuts...
have you ever washed your baja only to cut your hand all up on the sharp edges? I have.... decided to soften those edges by welding square stock to those areas...
Have always wanted to do a watson steet wiring kit so I stripped out all the old wires for a new clean, comprehensive fuse box and wiring harness...
welded all the holes in the trunk that have been drilled through out the years and where the old fuse panel came through the dash... a little por 15 rust encapsulator...lots of sanding then painted the trunk door jams and under the dash...
more to come....
Post Post subject: Re: Little red baja build (picture heavy)
Posted: Tue Jun 26, 2012 11:52 AM
You've done a ton of work!
blubaron66
blubaron66
Posted: Wed Jun 27, 2012 04:12 AM
A few more pics from this weekend's project. sprayed sound and heat insulation in the engine compartment...
Posted: Wed Jun 27, 2012 04:23 PM
It is looking goooood. Keep us updated. By the way what year is it looks like a 69?
blubaron66
blubaron66
Posted: Thu Jun 28, 2012 04:06 AM
the bug is a 1970. its funny, I never realized when I removed the dash cover for painting that underneath was the metal dash that the earlier bugs have. It looked like volkswagon simply added the padded dash right over the old metal one with virtually no modifications.
Posted: Sat Jun 30, 2012 01:23 AM
That was to meet US safety rules, every were else I think it stayed metal.
Posted: Sat Jun 30, 2012 02:56 AM
Good old Ralph Nader
blubaron66
blubaron66
Posted: Sun Jul 01, 2012 04:23 AM
Spent a little time making a shelf for where the front apron and body meet. cut and Riveted Aluminium diamond plate then sealed the gap with seam sealer. cant count how many screw drivers and small parts I've lost through this little black hole on past baja's.
Posted: Mon Jul 02, 2012 04:58 AM
Looking good.
sandfreaks
sandfreaks
Posted: Tue Aug 14, 2012 05:57 PM
Nice work! I really like how you Cleaned up the cut sheet metal.
Ive cut my hands a few times reacing into tight spots on
past bajas that I just cut the sheet metal and left.
Hope to see more!
69 baja
67 standard
Death: Life's way of saying: You can let go of your ankles now.
hood123
hood123
Posted: Tue Aug 14, 2012 08:21 PM
Nice looking build! Mine got t-boned by a motorcycle, rebuilding it now.
4 Admin_AzBaja 6550 Baja Bugs on Wiki need...
1568 mufasavnvmc 986140 Re: what did you do to...
285 MusicManiac 237983 Re: Baja sightings
0 Northmountainauto 1343 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 3745 Baja hiding in Chandle...
