Visitors: 110
Total: 110
12: Event Calendar
20: Pictures
42: Pictures
65: Event Calendar
88: Pictures
93: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Does anyone have any 33" tires on a wide 5 rim.
Ejbbal21
Ejbbal21
Post Post subject: Does anyone have any 33" tires on a wide 5 rim.
Posted: Mon Jan 23, 2012 02:19 AM
I'm thinking about getting some 33's for my baja but I'm not sure what it will do to my drive ratios. I have a turbo charged 2332 with a 091 trans with stock gearing. I'm wondering if anyone has some 33's that I could barrow for an hour or so. I will do all the swapping and bring all the tools if needed. Thanks.
Ejbbal21
Ejbbal21
Posted: Mon Jan 23, 2012 02:22 AM
Oh yeah I live in the east valley.
gman3850
Colonel
Colonel
gman3850
Posted: Mon Jan 23, 2012 02:43 AM
ya i do there low on tread but i got some
Post Post subject: Re: Does anyone have any 33" tires on a wide 5 rim.
Posted: Mon Jan 23, 2012 03:51 AM
I run 33s on my fasty, stock 091 and a normally aspirated 1915. They work nice. Still has enough gear to pull on the bottom end, but nice freeway cruising speeds. I would loan you mine, but I am prepping the car for transport the first of the week because I sold it.
Ejbbal21
Ejbbal21
Posted: Mon Jan 23, 2012 06:35 AM
Darrel congrats on the sale. What brand tires and size do you have on your car. I'm looking for some ideas. I have been running 30X9.5X15 and they are way too small. Gman I got you message I will give you a call next early next week.
gman3850
Colonel
Colonel
gman3850
Posted: Mon Jan 23, 2012 06:43 AM
the tires i have on it or 33x12.50x15
Ejbbal21
Ejbbal21
Posted: Mon Jan 23, 2012 07:12 AM
Sweet I can't wait to see how it drives.
Posted: Tue Feb 07, 2012 06:33 PM
Drove just fine right? With 33s all around you be amazed how softer the ride is off road.
Ejbbal21
Ejbbal21
Posted: Tue Feb 07, 2012 10:04 PM
They do ride nice but I want a little smaller tire. The ones that i have on there now are 33X12.5 I will prob go with a smaller tire. Either a 32X11.5 or 33X10.5 not quite sure which I want. My problem is my rear wheels are 7" wide I believe. I wouldn't be able to put a 12.5 on it, a 11.5 might be pushing it. Any thoughts?
Posted: Thu Feb 09, 2012 09:07 AM
On my Toyota I use 33x12.50-15s on 15x7 wheels. Perfect fit.
Most Class 10 and 12 racers run 33x10.50s on 4" rims.
33x12.50s are awfully big and heavy for most buggies. They also make for some poor geometry on the front wheel bearings and steering.
Posted: Thu Feb 09, 2012 05:06 PM
7s will work fine. My current tires 33x10.50 BFG Mud Terrains are on 5.5" wide rims and work fine. My previous tires were 33x12.50 BFG AT on a 7" or 8 " rim.
Posted: Thu Feb 09, 2012 10:08 PM
7's will work perfect. the skinnier wheel will allow the tire to protect the rim from rocks and other stuff that would cause a flat. also allows you to run a bit lower pressure and not have to worry as much about blowing a bead
68 Baja Beetle project build
3 Scrappy68 1277 Lets talk tires.
 Sat Aug 26, 2017 12:10 AM
No new posts VW Volkswagen & Baja Bug General Discussion Wheels and tires. Size is important? 0 andrewbaja 1799 Wheels and tires. Siz...
 Mon Jul 25, 2016 01:44 AM
andrewbaja View latest post
vw baja stock tires
7 iBeastSousa 3365 tires
 Tue May 27, 2014 10:12 AM
No new posts VW Volkswagen & Baja Bug General Discussion Tires question 4 vtbaja 2864 Tires question
 Sat Aug 31, 2013 05:22 AM
1engineer View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Class 11 and wide-eye mix
19 phulc 8344 Class 11 and wide-eye ...
 Mon Jul 22, 2013 07:50 PM
biblethumpncop View latest post
