Visitors: 130
Total: 130
20: Event Calendar
23: Contact Admin
26: Event Calendar
54: Event Calendar
58: Event Calendar
71: Event Calendar
73: Event Calendar
86: Pictures
89: Event Calendar
110: Event Calendar
121: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- bus shifter into bug
ghettodish
ghettodish
Post Post subject: bus shifter into bug
Posted: Sat Nov 05, 2011 09:18 PM
I'm doing a body lift on my 70. I think my Scat shifter will be too short to reach comfortably. Can a taller Scat shifter for a bus bolt right into a Bug?
edit: never mind....I forgot my plans to put the shifter on top of the tunnel...
Posted: Fri Nov 11, 2011 02:27 AM
I say yes. But you need to check with some one that has done it just to make sure.
Post Post subject: Re: bus shifter into bug
Posted: Fri Nov 11, 2011 03:28 AM
Yes, You can use a bus shifter.
siacs
siacs
Posted: Mon Nov 14, 2011 02:09 PM
Is it just a simple swap ? I thought the length of the ball (the ball that goes into the tunel into the shift rod ) was longer on a bus shifter.
No new posts VW Volkswagen & Baja Bug General Discussion problems with my shifter...
20 Neander 9476 Re: problems with my s...
 Mon Aug 11, 2008 10:27 PM
Neander View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Shifter Rod 4 anhedonite 1904 Re: Shifter Rod
 Fri Feb 08, 2008 06:09 AM
