Latest: Curtis
Overall: 3613
Visitors: 120
Total: 120
07: Event Calendar
10: Pictures
18: Event Calendar
24: Event Calendar
39: Event Calendar
44: Event Calendar
45: Event Calendar
53: Event Calendar
61: Garage
63: Event Calendar
65: Event Calendar
96: Event Calendar
117: Groups
118: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- alright lets see what u guys say
69baja69
69baja69
Post Post subject: alright lets see what u guys say
Posted: Tue Aug 30, 2011 05:48 PM
so i was talking to my best friends significant others father, who was a fabricator for walker evans many moons ago and a few other companies and his thing is custom chassis, whether its street or dirt, he was telling me widen my linkpin axle, stretch it forward as far as i can, run with stock torsions and 3x3 arms with good shocks,(front and rear) and it should be a hell of a ride, he builds many 1600 cars and 1400 trucks and an occasional unlimited. so souynd right?
Posted: Tue Aug 30, 2011 06:29 PM
Sounds right but wide isn't always that necessary. Suspension travel is only a number. It's all in the shock tuning. Will a properly tuned wider suspension baja perform better than properly tuned stock length and width baja, yes. But it's all in tuning. Don't expect a perfect car just by slapping on suspension. There's more to having a great performing car than just moving the beam forward and Putting 3x3s on
69baja69
69baja69
Posted: Tue Aug 30, 2011 07:35 PM
hes telling me put 4 front end adjusters and widen the front end by a foot with stock leaves and thats the way to go, inexpensively but im new to all this so figured id ask
Posted: Tue Aug 30, 2011 08:24 PM
widening the front end isn't going to do anything for gaining more travel unless you put longer arms on it. it's only making the car wider, which can be good at high speeds, but bad on tight technical sections/trails. adjusters is definitely the way to go, but you don't necessarily have to build one wider. and a foot is a lot to widen one. most go 6-8 inches
Post Post subject: Re: alright lets see what u guys say
Posted: Wed Aug 31, 2011 06:19 AM
A foot is a lot for a basic baja beam. Like James said, 6-8 inches is going to work well with 3x3s. I have a 10 over beam in my Fasty, but im also running 10" wide wheels in the rear and 5" wide wheels in the front. Both front and rear wheels are minimal backspacing. Pushing the beam forward will do it some good, but if you are going to do that you are going to want to do a full cage first. 4-6 inches is about the max I would go. I went 6 forward on the Fasty.
69baja69
69baja69
Posted: Mon Jan 23, 2012 09:11 PM
so basically building taller shock towers is just to run a taller shock?
Posted: Mon Jan 23, 2012 11:35 PM
basically yes. the benefit to a longer shock is that it has more volume, which means it doesn't heat up as fast. when the shock gets too hot it leads to fading, which will cause the shock to lose its dampening abilities, and thus a harsher, and sometimes dangerous/exciting ride.
with a longer shock, you open up the door to the possibilities of longer travel, but aren't going to gain travel just with longer shocks. longer shocks are necessary in order to gain travel though once you upgrade to longer arms
Posted: Tue Jan 24, 2012 05:26 PM
Before you do anything you need to establish your need. By saying that I mean will you be out on the weekend cruising on some trails or running hard through the open desert? One that is established you can then set your car up accordingly. Cruising trails does not require a lot of travel. However, if you are going the high speed route I would suggest looking at several other cars and talking to their owners. See what works and what doesn't.
Only after that can you make a plan and move forward. One word of advice is invest in good shocks. Fox, King etc . . . The last thing you need is an out of control suspension setup. You can go fast in the rough stuff without a properly setup suspension.
69baja69
69baja69
Posted: Fri Jan 27, 2012 10:09 PM
well, thats my thing is i have some local 4x4 trails which arent too crazy a couple river crossings and stuff but my baja will be running out in the desert since i ride dirt bikes desert trips will be funner for my fiance who doesnt ride and hates riding on the back through the dersert 5th gear pinned so she'll be able to cruise the baja with my sister or my buddys fiance, travel is an important thing to me since i cant drive 55 on pavement or trail, i got a few ideas it looks like ill convert the front end to A arms and the rear to 3x3s.
68 Baja Beetle project build
5 Scrappy68 6528 Re: Lets talk tires.
 Fri Dec 14, 2018 04:45 PM
No new posts VW Volkswagen & Baja Bug General Discussion new here. Any street guys from Mesa area? 2 ExtremeBean 4419 new here. Any street g...
 Fri Apr 10, 2015 12:36 AM
JWHracing View latest post
No new posts New Members hey guys new here.
finally registered
7 addandrew 5090 Re: hey guys new here.
 Fri May 31, 2013 05:28 AM
rileym_1989 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Some guys get all the luck 1 perrib 2245 Some guys get all the ...
 Fri Jan 25, 2013 04:04 PM
No new posts VW Volkswagen & Baja Bug General Discussion Not a baja buttt still figured you guys could admire it.
Long time No talky fellas, just checkin in!
10 bajaboi727 9682 Not a baja buttt still...
 Mon Jan 23, 2012 09:16 PM
69baja69 View latest post
