Latest: ecthemc
Overall: 3567
Visitors: 119
Total: 119
18: Event Calendar
58: Event Calendar
73: Event Calendar
98: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- 65 baja
65 baja
trockikox
trockikox
Post Post subject: 65 baja
Posted: Wed Aug 17, 2011 02:00 PM
any short list pros and cons on a 65? There is one a couple of hours away with no engine and trans for four hundred.
Any advice would be great.
t
Post Post subject: Re: 65 baja
Posted: Wed Aug 17, 2011 02:07 PM
Good car to pick up, last year for link pin front suspension. Since there is no trans, weld in the IRS conversion brackets and convert it over and then you will have the best of both worlds.
Posted: Wed Aug 17, 2011 04:55 PM
Just check the normal suspects. Bent rotted frame head, beam etc.
x2 on the conversion.
4 Admin_AzBaja 5041 Baja Bugs on Wiki need...
1567 mufasavnvmc 837170 what did you do to you...
 Tue Aug 15, 2017 03:29 AM
285 MusicManiac 205468 Re: Baja sightings
Off-road event
1 wideopenmotorsports 103 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 3118 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
