Latest: George
Overall: 3576
Visitors: 113
Total: 113
13: My Account
52: My Account
99: Event Calendar
106: Event Calendar
108: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- awd motor for baja bug?? need some help
lzugl
lzugl
Post Post subject: awd motor for baja bug?? need some help
Posted: Wed Jun 08, 2011 04:24 AM
Looking for a motor outa like a subaru with awd or 4x4 to put into my bug.. Has anyone seen or got any clue on what the best kinda motor and tranny to use for the rear mount motor?? im asuming a sideways mount motor would work the best but not sure.. Any info would be apriciated..
Thanks
Play hard get dirty nothing like it..
bajaben1
bajaben1
Post Post subject: Re: awd motor for baja bug?? need some help
Posted: Tue Jun 14, 2011 03:03 AM
you can buy an adapter plate to fit a suby motor in the vw, but you want to keep the AWD, in this case you will have to build your own motor mounts and also somehow reverse the gearing so when you put it in 1 you actually go forward, and the reverse makes you go backward, since you would be setting up the engine in the reverse order used in the suby. You would also have to find a way to mount your differential in the front, and shorten your drive line, not to mention find a way to get axles and all that good stuff on the front of your bug. you might even have to convert to A arms or something. possibly even a full tube chassis, since you are going to have a differential and drive line running down the middle of your baja. Hope this helps, I love subarus, and currently have a 05 legacy gt pushing 300 at the wheels
mlcbaja
mlcbaja
Posted: Tue Jun 14, 2011 03:17 AM
There's a guy here in Aus that makes he reversed crown wheel & pinion for the subaru tranny www.subarugears.com/
only prob is you loose the high/low range gears in the process.
Posted: Tue Jun 14, 2011 06:01 AM
There is a guy on D3 doing a Subi transplant with 2wd. This will give you some idea of what it takes to do a 2wd subi trans. An all wheel drive will require some serious mods to the tunnel area of the pan for a drive shaft, and a complete reworking of the front suspension and use of the subaru front components. We did some extensive metal work on the body for this guys project.
www.dailydrivendubz.co...9&start=15
4 Admin_AzBaja 5917 Baja Bugs on Wiki need...
1568 mufasavnvmc 927166 Re: what did you do to...
285 MusicManiac 223863 Re: Baja sightings
0 Northmountainauto 713 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 2353 Baja hiding in Chandle...
