Latest: George
Overall: 3576
Visitors: 117
Total: 117
02: My Account
13: Event Calendar
28: Event Calendar
31: Event Calendar
51: Event Calendar
53: Event Calendar
72: Home
73: Home
81: My Account
82: Event Calendar
91: Event Calendar
101: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Accelerator Cable
Accelerator Cable
Grizz
Grizz
Post Post subject: Accelerator Cable
Posted: Tue Jan 30, 2007 05:15 AM
The end of the throttle cable that hooks to the go pedal keeps coming unhooked. It's a "S" shaped metal end that pokes through the hole in blah blah blah you know what i'm talking about. Any fixes to keep it from popping out? Thanks
bajasam96
bajasam96
Post Post subject: Re: Accelerator Cable
Posted: Tue Jan 30, 2007 05:40 AM
Are you loosing tension on the cable? If not its likely your pedal getting a bit worn out. you can either try to bend the S shape a little sharper or maybe a dab of glue at the end of it to prevent it from slipping through...
Posted: Tue Jan 30, 2007 07:28 AM
If you have a loose pedal it will do that too. I have found on the aftermarket roller pedals, you have to stick a thin flat washer in the groove with the pedal to keep it from flopping side to side. Putting in a flat washer tightens it up and keeps the cable from popping out.
Posted: Tue Jan 30, 2007 03:34 PM
some have even drilled the hole out in the pedal and use a nut and bolt to hold the cable on. this is a bit more stable and you dont have to hook through the pedal arm then.
No new posts VW Volkswagen & Baja Bug General Discussion sticking accelerator cable 11 65bajabug 4196 Re: sticking accelerat...
 Wed Mar 13, 2013 12:29 AM
nshoe18 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Throttle cable shenanigans... 4 fast_1 2333 Re: Throttle cable she...
 Wed Apr 22, 2009 02:23 AM
fast_1 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion throttle cable.
20 shpuz 3833 Re: throttle cable.
 Tue Jan 22, 2008 01:11 PM
kcnaz View latest post
No new posts VW Volkswagen & Baja Bug General Discussion oy... throttle cable! 13 shpuz 6146 Re: oy... throttle cab...
 Fri Dec 28, 2007 03:47 PM
No new posts VW Volkswagen & Baja Bug General Discussion speedometer cable instal 6 todd 2695 Re: speedometer cable ...
 Sun Aug 12, 2007 05:46 PM
todd View latest post
